SOLVED: Possible failing differential, video clips included
*EDIT* The issue ended up being the slotted and drilled rotors. Apparently they are known for making this noise. I'm leaving this post up in case someone else has a similar issue in the future..
Hi everyone. I have a '23 CX-5 AWD with 27,600 miles on it. I am super good to the car and pretty much only use it for road trips and have owned it since 12,000 miles. I'm the second owner and purchased it from a dealership.
I was about to hit the road last weekend and immediately noted a new unnerving sound from the rear of the car. At low speeds it sounds kind of like growling or purring and at high speeds it sounds like whining. I ended up taking another car and haven't driven it since, except to try to figure out where its coming from. I ended up putting a go pro under my car and driving it. I also jacked it up and ran it at slow speeds. Clips included.
The noise is hard to pin down. It actually sounds like it coming from each rear wheel equally, but I suspect that it is translating from the rear diff through each axle I tried using a mechanics stethoscope while it was spinning but I couldn't really hear the noise through the stethoscope anywhere.
I should add that while the car is under warranty I live an hour away from the nearest Mazda dealership so I would like to try to get a good idea for what's happening before possibly committing to get it towed there.
Has anyone heard this noise before and can you confirm if it is consistent with diff. failure?
Thanks!
  • Untitled video - Made with Clipchamp.mp4
    46.9 MB
  • diff noise jacked up.mp4
    16.9 MB
  • diff noise jacked up 2.mp4
    12.6 MB
You have to wonder why somebody would get rid of a car with 12,000 miles.
Lucky for you you still have full warranty.
Upvote 0
Beyond checking the fluid level in the differential and brake pad thickness, take it to the dealership and let them figure it out.
Upvote 0
I had drilled and slotted rotors on my previous car. At first they didn't seem to make any noise, but after a while (maybe 6 months to a year?), I started hearing a similar noise as I cruised down residential streets with high fences. I guess the noise would bounce off the fences, and I'd be able to hear it with my music off.
I had Powerstop drilled/slotted rotors. Which ones do you have? Just curious.
Upvote 0
Lol yep, Powerstop.....and it's probably been about 6 months since I installed them. I actually figured it out when I saw someone else's video with a similar noise and Powerstop rotors.
Upvote 0
