Dealer won't use synthetic oil - 2022 CX-5 Turbo
No, but you need to take into account that tech can change quickly, and if he isn't present to learn about it and apply it to the advice he's giving, it could be a little outdated. He provides a lot of great info, but there's nothing wrong with challenging an opinion if you don't agree with it.
Consider the source too - a guy on Reddit claiming to be a master tech says change your oil every 3k. Meanwhile we have used oil analyses from certified labs occasionally recommending longer (8k - 10k mi) OCIs.
I wouldn't follow a recommendation to do 8 to 10k oil changes on a normal 2.5 NA engine let alone on a turbo, that's just crazy IMO, certified lab or not. Let's see what those lab results look like around the 100k mile mark or even 75k. 38k miles is still relatively young and buildup around oil rings takes time. There's countless videos up and down the web of high mileage engine teardowns with clogged oil rings because of extended OCI.
Modern engines have low tension compression rings which let by a certain amount of blow-by contaminating the oil to a point. Make the engine high compression and slap a turbo on top and you have more wear.
Now, if the OP isn't going to keep his vehicle long term ( over 100k) then he might be golden.
If he left Mazda in 2019 he doesn't know about the cylinder head cracks or burning oil issues in the 2.5T or the fixes. None of those would have been prevented with 3000 mile oil changes. Those are the only real issues modern Mazda turbos have had.
The early oci would have nothing to do with the cracking problems or design flaws in the T engines. Has to do with preventing early internal wear in the cylinder and rings found in turbo engines, hence the early spark plug change interval. Not that I'd do 3k miles, that is a bit wasteful, I'd still stick to the 5k regimen. His terminology was just turbo engines, not Mazda specifically, so maybe he was speaking generally.
OP here. Great read here...I think I will just buy my own synthetic oil. Which synthetic are you guys using?
Castrol Edge on my CX-5 Turbo, supposedly has very low deposits compared to other oil per an obscure Amsoil study I stumbled upon. Wouldn’t hesitate to use Mobil1 or Pennzoil either, I get whatever name brand is cheapest with rebates for my RAV4 hybrid.
I'll be using Kirkland Signature for the next 32k kms (20k mi). After my current stock is up, I may switch to a "high mileage" oil like Mobil1, or I may continue with the Costco stuff.
Before switching to Kirkland oil, I was using Castrol Edge, then switched to Pennzoil Ultra Platinum. Can't go wrong with those IME, though I did prefer the PUP because it seemed to make the engine feel just the tiniest bit smoother during regular driving.
I have a '22 CX-5 Turbo, and bought the dealer service contract. They change the oil every 6 months, but say it only needs conventional oil. I wrote to Mazda Customer Experience about this. They agreed that synthetic oil is superior, and said I should contact the dealer. My feeling is if the dealer really cared about doing what's best for their customer's car, they would use synthetic oil. Instead they do what is cheaper for them. I am going to cancel the remainder of the contract and demand partial refund. Anyone else have to put up with poor dealer service?
It would be good to see the outcome of this.
Even weirder my dealer only uses dino oil in the turbos but synthetic in the NA's. T
NA engines require a 0W oil, which is only available as a synthetic, or as a blend with a synthetic base. The 5W-30 oils meeting the certifications for the 2.5T are available in both conventional and synthetic.
Probably because you can get away with using the dino oil as it's a little cheaper than the synth.
Data point: I took my (CX-50) turbo into the dealer for oil change/service this morning and asked the Service Advisor the syn/conventional question... he said their 5W30 oil was conventional and that's what they use (and were told to use) for the turbos. We all (there were a couple of other service guys there) shook our heads and wondered how that makes sense.
I think if the question were asked of Mazda and we got a real technical explanation that would be great. Because no one thinks using conventional oil in the turbo makes any sense.
That's basically what I was told. I stated that in a post here last week and all hell broke loose in the comments.
If your 2.5 ltr is like every other SkyActiv on the planet, he should be putting the entire 5 qts in as 4.5 qts just doesn't get it.
You got that right. Mazda seem to use a Ouija board when it comes to oil capacities. Our old CX-9's owners manual was off by a quart(printed capacity was 1 qt to little!). Same for our two CX-5's. The owners manual capacity barely has the oil on the bottom mark. Nevermind the piss poor dip stick design.
A little hard to understand, I'm glad that a 5 qt jug seems to be close enough, which is very convenient.
If he is master tech status, you can't discount him that easily.
Anybody who claims 3,000 mil oil changes immediately loses me. That was a recommendation...in 1940. Surely something has changed since then...
My supercharged and turbo charged Volvo got oil changes every 10K miles. Currently at 80K and purrs like a kitten.
I'll be happy to do a lab in 20K more miles.
The CX-5 turbo owner's manual has the correct capacity of 5.1 quarts.
Depends on how long you want to keep it. Like I said, buildup around rings takes time. If you did a tear down around 200k you'd see the problem. Plenty of videos around showing this because of extended OCI. 100k come to think of it is relatively young these days. Running great now doesn't really tell you anything about what's building up internally.
