CX-5 heater questions
First post so hey everyone! I'm working on a friends 2016 CX-5 that he said had a few problems that I pretty much figured out except he said it overheated on him once while getting his oil changed and the guy topped off the coolant. I got it towed here because the starter went out but I got that changed and it's good now. I drove it with my scanner on it and it never got over 190 degrees so I assumed it was a fluke of some type maybe. I was getting ready to tell him it was done but happened to check the heater and it's blowing cold. Both heater hoses are cold also so I'm guessing the blend door is ok.
Figured I'd check codes and got a P011A? My scanner says recommended fixes are temp sensor or thermostat. My guess is the code is from the flow problem. What would be your suggestions be for the first thing to look at? Do these cars have a coolant control valve inline with the heater core hoses? Thanks for any help.
There is an issue here.
You might need to change the core, there are Youtubes on how to do this without removing the entire unit, but you have to procure the small heat exchanger that fits in the unit.
Backflushing might not work because corrosion has built up inside the pipes.
I did see the video on using the factory metal lines and re-crimping on the new one and that sure is the way I'm gonna go if needed but what do you mean by the small heat exchanger? Thanks
Definitely a flow problem. Just put it back together and let it run for a few minutes and temp sensor 1 was 164 degrees while 2 was 67. Top rad hose was getting hot but bottom was cold. Maybe thermostat is stuck closed?
There was a TSB for the coolant control valve, however my understanding is it defaults open, not closed, when it fails.
It also doesn't list 2016 as an applicable year.
Maybe you just need a thermostat.
Who removed my link? Adding it again. Do not edit my posts.
Discussion on the CCV was here:
Thanks, gonna try a stat next.
Sounds like thermostat stuck closed. I changed mine last year ( no problems... just being proactive along with both radiator hoses). The lower hose goes to the thermostat housing and it's a bit of a job to get to it. I don't think a 2016 has a coolant control valve but I could be wrong.
Be a good time to do a coolant changeout if it's never been done. Personal preference is to definitely use a compatible coolant and not some "fitzall".I use ZEREX Asian Formula (blue or green).
I installed an OEM Mazda thermostat as the original functioned fine for over 10 years and it's too important to trust the chain store cheapies. It's one place I won't save buck to risk an overheat, breakdown or engine damage.
Compared to thermostat and hose changes this was a lot more work than previous cars. It was nice when you popped the hood and the thermostat housing was right there on the top radiator hose. Guess those days are gone.
You're right about that! Those were the days when you could change one in a few minutes. I was looking myself for a valve and as you said, I didn't see one for this year. Getting a stat today along with coolant and hope for the best.
Since Mazda adjusted the FL22 formula to reduce corrosion, how can we be sure the Zerex is safe?
To me the question isn't why a long established product from a reputable manufacturer is unsafe but rather what is so different in Mazda's system that causes this corrosion. Was it because the factory coolant formulation at the time was insufficient to withstand the long 10 coolant service interval and degenerated causing corrosion. And now it's been revised with more anti-corrosion additive. Does the aluminum alloy used in the heater core require some exotic coolant formulation (doubtful). Or is there something else causing the corrosion. Maybe galvanic action between aluminum block and steel cylinder liners causing coolant breakdown. Who knows.
Whatever the reason, I'm not convinced that ZEREX is "unsafe" anymore than FL22 is "safe". I'll just continue to observe reasonable changeout intervals of 4 years or so. Might get some pH test strips and monitor for coolant pH changes to see if it starts trending toward the acidic direction. The 10 year initial coolant interval (along with the "lifetime" transmission fluid) struck me from the get -go as being questionable. My changes were at the 6 year and 10 year mark, both with the Zerex Asian formula. So far, so good. It's been about a year, I think I'll check the heater inlet and outlet temperatures for evidence of blockage/reduced flow. Haven't really used the heater since springtime.
Would love to hear other member thoughts, speculation or solid information on this subject.
EDITED to add: after further thinking, are the cylinder liners even exposed to the coolant (like some diesel engines) or do they "sleeve into" the block separated from the water jackets.
