OBD2 Scanner/App: what sensors/values to monitor?
2017 CX3 AWD
Do any of you keep your OBD2 scanner on to monitor values not shown on the car's dashboard? I have a spare Android phone that is now doing that job. Besides coolant temp (194~214), ATF temp (188~208), battery/ECU voltage (14/13), there are many more sensors to choose from the app. I understand that not all of them are available for my specific car/connector. What are some other values that are useful to monitor and log? It's a 2017 CX-3 that didn't need extra attention until this year (after 153K+ miles). Thank you!
Which obd2 scanner/app combo you're using, I'm thinking to do the same for 16' mazda 3.
Temps and voltage are easy to monitor, most engine parameters are best data logged then reviewed afterward until you find a set of parameters to review live.
It gets cumbersome to review live engine parameters constantly.
I bought a Veepak BT dongle for the BimmerLink app when I was working on my R56 in July. Now that it doesn't start any more, I use the dongle on the CX-3 with the Car Scanner Pro app. I forgot what additional features I got for $5 extra. It's nice to have 6 values displayed on one page and I can have multiple pages.
It seems to depend on the vehicle. I usually look for the low teens for idle, mid-twenties to thirties cruising. Accelerating it will be in the 30's-50's. There are times when I have the pedal down a bit, maybe halfway, and the TPS jumps from the 50's to 91 on it's own, possibly for efficiency. I'm not sure if it ever goes over 91.
I'll give this obd2 a try, had an old one but its not working anymore.
This wasn't the latest version though, it was the one that I could get overnight by Prime, at the time. 😅 I could have waited two more days and paid $10 more for the latest version.
Thank you! I will see if I can get the TPS values with my scanner/app.
Engine oil temp is 207 in the morning and 215 around noon. On my longer weekend trip it can go over 220. Is this normal? Never tried to read the engine oil temp before. If this is high, what could be the contributing factors? 😅
Normally that is based on coolant temp. I am not sure what happens if oil temp gets too high, but that would be north of 250°F on the oil. I think the ranges are similar though.
Hey if you haven't bought a BT dongle yet, please search on this forum for Forscan Lite. That's the most comprehensive app for Mazdas. There are specific OBD2 devices that are compatible with the app. 🧐
I got vGate vLinker MC obd2 which would work with my triumph motorcycle as well.
Been looking at Forscan, might get that but in the mean time I'm using the Car scanner app and tracking some aforementioned engine parameters.
I've noticed the only voltage reading is that of the PCM and its max is 13.65Volt, not sure if there's no measurement from the alternator/battery or if the Car scanner can't get that value from alternator/battery.
My next oil change is in two months so I have the OEM filter ready to go with Idemitsu 5w30. Will find out if that combo runs at the same temp, cooler or hotter. 😅
Turbocharged cars do run hotter than NA variation.
