2007~2015 CX-9 Front sway bar bushing replacement difficult?
2007 Mazda CX-9 Touring
Was just wondering if anyone has ever changed their front sway bar bushings on their first gen cx-9. How difficult is it to do..?
If you find out about this please let me know. The rear are straight forward, but the front looks extremely difficult. I don't know what possessed Mazda to place the sway bar bushings in this position.
While I haven't done it, I have looked it up in the past. The short answer is yes, it's difficult because it's very hard to reach. You will be working partially blind.
I did the hard way the first time because as others have said there is not much room in there. The "easy" way (LOL I know it's not really easy it's a PITA).
1. Put the car on Jackstands and remove the front wheels.
2. Put a jack under the engine or suitably support it then remove the after bolt on the torque strut.
3. Disconnect the stabilizer links from the stabilizer bar.
4. Remove the intermediate exhaust pipe section from the Y-Pipe to the muffler.
5. Put a jack under the after part of the fwd sub-frame to support it..
6. Loosen the fwd subframe fasteners but leave on (19 mm nut).
7, Remove the 19 mm nuts from the mid-subframe.
8. Removed the 2 triangle plates at the rear of the subframe (19 mm and 17 mm).
9 Using your jack slowly lower the rear subframe just enough to access the stabilizer bar clamps and no more. If you go much lower you would have to disconnect the steering shaft and the ball joints. You can safely lower the rear end of the subframe a few inches to access the bolts. Your steering wheel shaft has a floating spline that will accommodate a few inches of movement without a requiring disconnect, just keep an eye on it.
10. Change you bushings..
11. Reassembly is the same process reversed. Torque the subframe fasteners to 95 ft/lb.
I did it the hard way the 1st time. I just changed my steering rack on my 2012 CX9 and had to remove the stabilizer bar. It takes about 45 min to lower the subframe and about 1 hour to reassemble it all using using an impact gun and power watchet. You will need 2 exhaust gaskets for re-assembly (1 Flange and 1 crush) Auto-zone had the gaskets in stock, O'Reileys did not. I had to figure this procedure out on my own with a little help from AI as no one had a tutorial on any of this for a CX9. Not HARD, but it is a major PITA to have to take so much stuff apart just to access some stupid bolts.
I hope this helps some of you
I hope you didn't actually mean the engine! For everyone else's information, the car should only be supported on the crossmember with the dimple pattern on it:
Otherwise, great write-up. Labor intensive indeed.
I did mean put a jack under the engine. I used a bottle jack and a piece of wood. The reason being is that you are removing the bolt from the torque strut or the after motor mount. What you are doing is trying to make sure the engine and transmission do not rotate about the horizontal axis. There should be very little force on the jack. Your engine is supported on the left and right sides. One is called the motor mount and the other the transmission mount. The torque strut is the 3rd motor mount that soaks up rotational torque due to the transverse mounting. You are merely preventing the motor from rotating and over stressing the motor and transmission mounts. I removed the jack and used a prybar to rotate the engine and align the bolt holes when re-assembling.
I would not have guessed that. Thanks for explaining. But there has to be a better way.
