Looking to buy a 2024-2025 CX-5 2.5NA
2016 Mazda CX-5 Sport & 2010 Toyota Corolla LE
Looking to buy a 24-25 CX-5 to replace my 2010 Corolla. Just need some advice. I know that Mazda has had the cracked head issue with the 2.5NA engine. I believe it was due to the cylinder de-activation system. It looks like the 24-25 2.5NAs that I am seeing on auto trader don't have the cylinder de-activation and the eight digit of the VIN is "L" instead of "M".
Would these models without cylinder de-activation could potentially have the same cracked head issue in the future? The reliability ratings on Consumer Reports and they are very good for 2024 including powertrain.
Also, any suggestions for extended warranties?
I believe some later models came w/o CDA because of a parts shortage. Nothing to do with cracked heads. You're safe buying one of them.
Only some 2024 models (any trim) with L vs M in the Vin. Due to shortages at that time. I think bult from Oct 2023 till sometime early 2024.
If you dont want CD , look for those 2024 models that have the letter in the VIN
or for 2025 only the lower trims dont have CD by default. Vin doesnt matter.
If you buy a Mazda CPO it already has extended engine warranty and +1yr on the 3/36 warranty. So for a CPO i dont recommend extended warranty.
Only some 2024 models (any trim) with L vs M in the Vin. Due to shortages at that time. I think bult from Oct 2023 till sometime early 2024.'
Also, does it usually indicate on the sales sticker on the vehicle if it has cylinder d-activation? I saw a deal for a new 2024 CX-5 2.5 S Select AWD online. I managed to pull up the window sticker online, but it doesn't state cylinder de-activation. Also, the eight digit of the VIN is 'L'. I have seen threads on this forum that indicate if you see an 'L' you don't have cylinder de-activation.
"Only some 2024 models (any trim) with L vs M in the Vin. Due to shortages at that time. I think built from Oct 2023 till sometime early 2024."
Isn't that what txt990 said?^^^
As far as I know, the 8th character VIN method of determining whether a CX-5 has cylinder deactivation is reliable (L = without CD; M = with CD), but if you want another way to tell, look at the cylinder head. If it has one of the things in the attached picture on each end, the engine has cylinder deactivation. Those are solenoids that control oil flow to the switchable valve lifters that turn CD on and off. They're both fairly easy to see, but the one on the driver's side (assuming USA models) is toward the front of the car and the one on the passenger side is toward the back.
I went to the dealership in South Florida. Since I am a Costco member the dealership is offering me a 2025 CX-5 S with the Costco discounts and Mazda Loyalty discount for $26,555. The blue color. Out the door price is $29,295 with sales tax, tag & tile fees. The car does not have cylinder de-activation. the VIN has 'L' in it. Confirmed with dealership.
Their Internet price is $29,519 plus tax, tag & title, & dealer fees.
Also, confirmed on the window sticker that the VIN 'L' model doesn't have cylinder deactivation. On the 'M" model, it says cylinder de-activation.
the tag on drivers side door pillar should tell you vin,it was most likely built in japan during mid to late 2024,is it a select model?
It's a 'S' model. Bought the car and it doesn't have cylinder de-activation. Confirmed on the window sticker. Some models above the 'S' have it which is indicated by the window sticker and also 'M' on the VIN.
