On mine, no lubrication altered the "creaking" noises. Particularly when very cold winter temps it (sub-0ºF), nothing would make it function well. It was still bolted-in and all, still moving, no breaks in the arm itself ... just very noisy operation.
Then you must need a new door check arm. In my case whenever the creaking noise starts happening from the check arm, a lubrication job even with WD-40 would quiet it down nicely and for a long period of time.
Yeah. Something in the "control" end of the arm assembly had seized up. No amount of lubrication would change its operation. Peeking in through the arm's access "port" area, it's clear that the delrin (?) component inside had been failing, as it was chewed-up and marred. However it actually holds onto the arm and/or attenuates the arm's movements, that had failed. Door still worked, but the arm's "guts" (inside the "business" end of things) wasn't doing well. The swap works nicely. It's utterly silent, now.
Might do an annual spritzing of a plastics-tolerant lubricating spray, into that spot on the various arm assemblies on each of the doors. If nothing else, to help keep minor rusting at bay, and to help keep that delrin/plastic piece as "slippery" as possible for the arm. Still, even without doing that, it's likely now got 10+ years' worth of life coming. Hardly a must-do.
Got up early and installed some ROKBLOKZ mud flaps.
I have just installed a new USB Hub allowing Wireless AA/CP.I was a bit sceptic since I had to do all the dirty job / installation , but at the end of the day I got there and all works fine. It is a great addition to my car.
just needs the strut bar and battery tie down
and pink mazdaspeed radiator cap lol
I checked the Auto Exe battery battery tie down but I decided not to buy it. And funny that you mentioned the radiator cap because I did search the internet for a red radiator cap and a windscreen fluid reservoir cap but no joy.
I went with LEDS in all the interior lights, huge upgrade makes it feel much more premium. For the dome and map lights I have the LEDs facing inwards towards the vehicle as I found them too bright shining out.
where did you buy the lughts from and did you DIY the lights?
It took literally close to 2 months going back and forth with Mazda USA and the Dealership.
It was going to be $6k+ for the repair and Mazda USA approved a goodwill out-of-warranty repair but the $$$, which was not even half the repair cost, was a joke. This is where the dealership came in and we agreed on the $$$.
Once I get it back, hopefully next week, we will see if the dealership lives up to that said $$$ amount.
DONE.
Got the car back and everything is all good!
For those folks in Houston, I would highly recommend #DeMontrondMazda in Clear Lake. Ask for Dylan.
Oil change, fixed the pesky leaking seal on the oil control valve, washed out the AEM filter, new front rotors (one had developed a shudder when braking at high speeds, pads still 80% or better), and a good vacuum/wash/quick detail as a thank you for yet another family vacation (~600 miles) gone smoothly. Still love this damn thing.
Next up is definitely an alignment. I noticed some scalloping on the inside tread on both left wheels. I haven't had the alignment checked since I put tires on it in late 2019, so it's definitely due for some attention.
First time poster - Only purchased my first Mazda a couple months ago and what a beauty!
Interior clean for me today, including leather treatment. Next weekend I'll be working on getting rid of ome of the slight blemishes in the paint work.
Quick question - the small scratches in the plastic around the shifter - What's best to use to get them out?
I used a polish and a small rotary polisher on my 2018 CX-9. It worked well but the scratches will just come back. Piano black suuuuucks
Here's a link to my process, and a before and after pic. I recommend taping off the silver trim if you're using a machine polisher to avoid accidentally polishing through those parts.
20250402_110821-webp.335939
20250413_202017-webp.335940
Thanks for this! I'll give it a go
I use this with a micro fiber cloth:
