New wheels/tires. Couldn't be happier!😁
60k miles on 21 CX5 GT non turbo
New brakes and rotors
Front and back
(local mechanic-I bought parts) 3 hrs of labor
Akebono ProACT
Raybestos Element3
DIY spark plug replacement (15 min)
NGK Ruthenium HX
(Original plugs, all 4 looked like the picture)
Right. Eh. Close enough. Lol
It's probably just an illusion then with the body panels. CX-5 KF has some junk in the trunk. Overall I think it looks better, though. The 1st gen looks more soccer mom or high-school girl while the 2nd gen looks more like anyone could own it. They may have intentionally tried to broaden the appeal.
I agree. But I prefer the previous gen for being lighter and more readily available with FWD.
Then again, I am biased due to owning a Mazda 6 from that era of styling..
I was hesitant on AWD. I always preferred FWD due to lower cost and better economy.
But I have changed my tune. I now prefer Mazda's current iteration of AWD. There is very little hit to economy if any at all since they moved to 100% FWD during constant speed cruising, and the handling improvements are real.
Sounds like a practical perspective. I also like that FWD is considerably lighter, though, having a driveshaft that's relatively distributed towards the rear of the vehicle does help with weight distribution.
The turbo 2.5 makes such a generous wallop of torque - you sort of end up needing the AWD system. When I was messing around with the CX-5 turbo demo, I was amazed and not at all expecting the system to shove power to the rear the way it did - high throttle cornering from low speed. It oversteered with a level of precision and response I never thought to be realistic for such a heavy vehicle. However, for normal driving, I can't justify the extra weight.
Then there is the argument of wet traction. While a FWD car is not balanced like a RWD car, it is perfectly fine with good tires and an LSD. Open diffs are crap. Take a look at what Honda/Acura has been achieving on a FWD chassis for decades.
Lower trim CX-5's with the NA engine, 17" wheels and FWD address the biggest gripes I had after testing the signature turbo - but then again, like I mentioned in my review, my preferences and requirements in a vehicle are drastically different from the average consumer, and I unfortunately I don't think the NA will offer quite enough grunt for even a lighter base model CX-5 on 87 octane.
Concerning my 3200LB Mazda 6 with the 91 octane tuned NA and 17" wheels, these things just aren't an issue like they are on the CX-5 I tested. - Back to the topic of FWD vs. AWD. The only problem I have experienced in starting off in snow, and that's because of the open differential, not the fact that there is no power being sent to the rear. In another life, I drove a 1995 Nissan Maxima SE with the very rare 5 speed manual and LSD stock from the factory. That thing put down V6 torque to the front wheels unimaginably well.
It's only 3,800 lb, the same as a BMW M2. You want to talk heavy vehicles, let's talk Stellantis. I'm pretty sure Mazda can make something to rival the Trackhawk, but at a much lighter weight and with much better handling.
The driving experience of that is significantly worse in every conceivable way except ride comfort--but wheels and tires can be changed, the rest cannot be. I have owned every version of the CX-5 over the last 11 years.
I just swapped out the control arms for OEM 2nd gen units on my '14. One of the bushings had cracked through, so I just did both sides. I'm getting some odd tire wear up front so I'm hoping this (along with an alignment) gets everything in order.
As for the recent posts FWD vs AWD, give me the simplicity and efficiency of FWD any day for my particular needs. I drive my cars well into the 200-250k mile range, and they're 15+ years old by then. Parts that aren't there can't fail :).
Dude. It's a crossover. You don't buy these for a "real" driving experience.
And 3800LB is heavy.
📦 Need Mazda Parts Fast?
Get Free 2-Day Shipping with a 30-Day Prime Trial
Try Prime Free →
