Common Repairs Thread
2018 CX-9 SIGNATURE
Here’s a chance to share your repair misery.
🙂 Any 2016+ CX-9 owners have a significant repair? This should’t include common TSB items (such as faulty infotainment screens) or the dreaded cylinder head crack.
- Water pump replaced 65k
- Brake booster replaced at 117k.
Just curious to see if there are certain common repairs to these vehicles. Thanks in advance.
2018 CX-9:
Rear diff replacement at about 110k kms (~68k mi)
Front passenger side LCA and both front struts replaced at around 120k kms (~74.5k mi) - this was due to hitting potholes with 285/35/22 tires while being lowered on CorkSport springs.
Upcoming thermostat and ECT replacement at about 139k kms (~86.3k mi)
2022 CX-9
Oil control valve (small leak) replaced at about 45k kms. I think this is a common issue on these motors?
2022 CX-9
Is that the one at the top of the engine (passenger side, near the firewall, under the engine cover)? I have a small leak there as well, very minor.
Yes.
They replaced the entire OCV and the plastic engine cover (didn't feel like cleaning it?).
Was never enough to see any changes (significant an otherwise) to the oil levels between change intervals, but just visual (I, like probably many others on the forums, actually look inside the engine bay every so often).
