I am getting close to 40k miles on my 2.5T and the dealer recommended their replacement today at my 35k oil change. The cost? 407.00 which seems excessive to me. I contacted another shop which did my transmission fluid change and they quoted 227.00. This too seems like a lot when I can buy NKG iridium plugs on RockAuto for $60. What is a fair cost for having the plugs changed? Is there anything else which needs to be done at the same time (coils/boots)? I also thought about buying the plugs and having a mobile mechanic come and swap them as I had this done for the front rotors/pads and it went well. I don't have the tools needed, so with adding that cost to the mix, it may make more sense to have it outsourced. Maybe Callisto will be kind enough to tell me what this would cost at his shop?
On another front, It seems my motor is starting use some oil. I noticed it a couple of thousand miles ago and added oil and it was down a tiny bit 1500 miles later(it never used oil in the past). I asked about the stem seal replacement under warranty today and was told I had to let the oil get low enough for the low oil light to trip so that there was a record of it in the cars computer. Then they will do the replacement. I will keep driving with the fresh oil and see what happens.
2021 CX-5 2.5T
2021 CX-5 2.5T
