Spare wheel TPMS question
For a 2024 Maxx Sport: if I buy a wheel off a wreck to use as a full size spare, what happens about the tyre pressure sensor?
Will it play nice with the 4 already on the car?
Will it cause issues?
Or do I need to buy a base Maxx wheel that would not have a sensor in it?
Thanks
Doug
There is no registration or pairing process; if it's set up for Mazda, it is automatic. I'm not sure if the wheel position is close enough to be picked up.
Ok, so the real question is then, will having 5 sensors talking to the car instead of the expected 4 confuse the computer?
The sensors only turn 'on' when the wheels rotate, so the 5th one should be mute.
You can be the crash test dummy!
Worse case scenario = if it causes problems, take the wheel into a tyre place, deflate it, pop the tyre off the bead and remove the sensor from inside. Reinflate tyre. Get it rebalanced.
Keep the sensor as a spare.
