The main things your spark plugs tell me, is likely hard use. I would have suspected a hard pedal, but you said that it's a family workhorse, so that explains it.
Turbo Skyactiv's run richer than the NA, and it shows, looking at the thread on your spark plugs. They're dark. The turbo requires more frequent spark plug changes.
 The light golden coloured on my spark plugs thread potentially point towards lean AFR's, which the NA is known for.
Other than being more gentle on the throttle (seems you are at half throttle alot, based on your pic) I would suggest to change oil sooner.
