Minimum thickness for front rotors? 2014 CX-5
Hi...I'd like to know what is the minimum thickness for front rotors on a 2014 Mazda cx5 sport AWD so I know whether to resurface or not. Thanks.
Link to service manuals for various Mazda vehicles @ MazdaManuals.com.au:
Per the manual reference, for the CX-5 (@ page 4251 of 6714 in the 2014_CX5_FSM file):
2014 - CX-5 - Brakes
BRAKES TECHNICAL DATA
Front brakes:
Minimum front disc plate thickness 26.0 mm {1.02 in}
Minimum front disc plate thickness after machining using a brake lathe on-vehicle 26.8 mm {1.06 in}
Minimum front disc pad thickness 2.0 mm {0.079 in} min.
Front disc plate runout limit 0.04 mm {0.002 in}
Rear brakes:
Minimum rear disc plate thickness 8.0 mm {0.31 in}
Minimum rear disc plate thickness after machining using a brake lathe on-vehicle 8.8 mm {0.35 in}
Minimum rear disc pad thickness 2.0 mm {0.079 in} min.
Rear disc plate runout limit 0.1 mm {0.004 in}
Upvote 0
Front brakes:
Rear brakes:
Thank you
Upvote 0
