ccyap
2013 Mazda CX5 2.0 Skyactiv G
Mazda Malaysia said the TSB only apply to North America and not Malaysia. But i am guessing Mazda Malaysia just doesnt care because TSB's are issued to protect Mazda from any lawsuit. Malaysia doesnt have a strong consumer protection laws and so Mazda just let it be.Yes if an automatic transmission failed at 67,000 km / 41,632 miles it’s too early. Like in the US, Mazda in Malaysia won’t do anything for a 10 year old transmission. $2.3K USD is much cheaper than in the US for an automatic transmission rebuild.
Honestly any older Honda 4 / 5-speed automatic transmissions like the one in your 1984 Honda Accord is more reliable than most modern automatics. The 4AT in my 1998 Honda CR-V has 192K miles so far.
Don’t believe the coolant gets in your transmission as the ATF cooler is attached outside of the SkyActiv-Drive transmission and it rarely has internal leaks. Like @jmaz said, is it possible the Mazda shop used wrong red ATF for change which caused transmission failure? Or it’s simply because the transmission is brand new at the time, the failure rate is higher?
As for whining noise it could be the front input bearing is failing. There’s a TSB for the problem and Mazda had to modified the front casing to prevent the problem happening in later model years.
Correct me if im wrong, prior to 2018 (that year Mazda opened an overseas Drivetrain Mazda factory, but im not in other parts of the world tho) all skyactiv engines and gearboxes for Malaysian market (should be the same for US market) are Made in Japan.
Our car was actually the No. 1874 car CKD in Malaysia but i can roughly see 80% or more parts still made in Japan, even up to the side mirrors. And yes @yrwei52 our car is the first batches of sky blue colour CKD in Malaysia (meant for Thailand and Malaysian market) . We had to wait for 6 months because my dad insisted on Blue. Prior that, all cx5's sold were CBU Japan.
I saw coolant and other hoses was removed to make way for the gearbox disassembly tho. I have not checked whats the coolant colour.
Checked in to this forum because Malaysian forums are not any technical and more to a hub of sharing the latest made in PRC add-ons into their rides
