- 2023 CX-5 2.5 Turbo AWD Auto
RIP 8/23:2013 CX-5 Sport FWD Auto 120k
Thanks for sharing your install details. I ordered and installed a Viofo A119 and the HK3 hardwire kit. I probably won’t use the parking mode at all, but the hardwire kit was nice as I can’t find the Dongar rear view mirror adapter in stock anywhere.Ok all done.... got the hardwire kit and finalized the install of the dashcam.
This is the battery saver. I kept it out and accessible so I can adjust the voltage if needed.
Here's the fuse box. I used #5 for the constant+ and #11 for the accessory+ (which was an empty slot).
Here's a couple of sample (sped up) videos for the AZDome M300S. I need to get a filter to reduce the glare. I wonder if the filter for the U1000 work for this one.
AZDome M300S - Sample 1 (2019 CX5)
youtu.be
AZDome M300S - Sample 2 (2019 CX5)
youtu.be
AZDome M300S - Sample 3 (2019 CX5)
youtu.be
I’m working on the Kahtec 3rd brake light flasher now. This is the third one I’ve installed and really like them. I opt for the “smart” version that has an 8s delay between brake pedal presses before it blinks again.
