2015 Mazda CX-9 Caliber Pin torque specs?
Does anyone know the front caliber slider pin torque spec for 2015 mazda cx9? I found Someone on google say its around 25 ft lbs and I'm seeing others saying 50 + ft lb
Ha, its not much. Probably below 25ft-lbs. Dont know why but caliper slide pin bolt spec torque is always scary lite
You want to be careful on this. On newer Mazda’s it can be 23~28 ft-lbf (front single-piston caliper) 、62~68 ft-lbf (front dual-piston caliper)、17~22 ft-lbf (rear caliper). It’s very easy to strip the threads or snap the bolt if you used a bit higher torque.
Does anyone know the torque specs for the rear caliper hanger and bracket, seems like a web search gives a wide range of numbers, from a high of 110 ft/lbs to a low of 85 ft/lbs for the hanger and a high of 30 ft/lbs to a low of 17 ft/lbs for the caliper
As opposed to any other car manufactures, Mazda likes to give a range of torque specs instead a clear and simple one value. Here is the rear brake torque specs on 2017+ CX-5’s and your CX-9’s should be similar.
