Aftermarket remote TPMS with readout. Anyone?
Phoenix
2021 signature
We've already lamented how it seems surprising that actual readout is not standard.
Has anyone used one of these types? They seem to range from around $50 to $250. And to the guy who has nothing more to contribute other than - "I just keep a $10 pressure gauge n my glove box" - thank you in advance for the non-sequitur (look it up)
Steelmate is a more famous name brand.
Not sure about Tymate.... sounds like a copy cat by its name.
My co-worker has the Steelmate installed.
He has been happy with it, and there is no air leak, which could be an issue with cheap clones.
FYI.
FYI.
Thanks, there's so many to choose, I was just linking to an example. Def appreciate the lead.
May want to use an anti-corrosion product on valve stems when you use these screw on type. I had to cut a couple off my snow tire set a couple years ago. They worked but wasn’t worth the hassle because sensors were destroyed on removal.
