Potentially, but it won't be cheap and it'd be coming from Canada. I can ask if you'd like.GotRice23: Is that shop considering making more adapters to sell?
@Kedis82ZE8 - The shop says they'd be willing, but they didn't make any measurements while they were doing mine. Therefore, they wouldn't be able to duplicate the adapter without another CX-5 in their shop. But they said they'd definitely reproduce the adapter if there is interest.Potentially, but it won't be cheap and it'd be coming from Canada. I can ask if you'd like.
	I just have an ultragauge that displays my engine temps, transmission temps, and I have since added EGT so I can monitor that and the regen.@GotRice23 I appreciate all the time you've taken to post your trans cooling adventure. Thanks!
What is your setup for your obdii reader/display?
My regen usually hovers around nearly 600 to 650 celcius without trailer. With trailer it reached 750 celcius max.@Coolpix99 Have you been monitoring EGT, especially during the regen cycle? What are those temperatures looking like for you? I've only just started monitoring them and it looks like I get around 1200 F or 649 C during the regen cycle without the trailer. I'm towing again in the next coming weeks to close out the camping season and will be watching mine closely.
Hmm, hopefully I run into similar results when I do my tow in a couple of weeks. Your emissions are probably now on par with North American standards! I know our emissions control system lowers fuel economy a tiny bit.My regen usually hovers around nearly 600 to 650 celcius without trailer. With trailer it reached 750 celcius max.
However, I decided to remove my dpf and egr just two weeks back and also installed an additional catalytic converter to reduce the diesel smell. One of the reasons was because my dpf was regenerating every 100km with the trailer on and low fuel light came up after 350km with the trailer on.
Hmm, hopefully I run into similar results when I do my tow in a couple of weeks. Your emissions are probably now on par with North American standards! I know our emissions control system lowers fuel economy a tiny bit. Follow up question - what kind of caravan are you towing and what is the weight?
So on tire pressure you follow North American Mazda recommended “one-size-fit-all” 35 psi all around, not higher pressures recommended worldwide, for heavier load and towing on your diesel CX-5?⋯ Tire PSI increase about 3psi to match the 30 deg F tire temperature rise.
It seems that all the EGTs reported here are pretty consistent. @Coolpix99 reported 1382 F (750 C) max during regen which is the highest next to your 1400 F (760 C). Hopefully mine are in that range too.Interesting thread. I too have been playing with the ForScan app and recording data to get a better idea what is going on "behind the curtain" of my 2019 North American 2.2 diesel. You guys are seeing / reporting higher temperatures than I am seeing. (I realize you are both towing heavier weights than I am)
I did a 600 mile trip last weekend with about 750 lbs inside the car and towing around 1000 lbs. on a flatbed trailer. Outside air temperatures were 75-80 deg F. Rolling hills in Kentucky and Tennessee. Max temperatures I'm seeing during a regen cycle while towing at 70mph highway speed .... (all deg F)
EGT 1380 (Exhaust)
ECT 198 (coolant)
EOT 223 (Engine Oil)
TFT 207 (Transmission Fluid)
RDT 133 (Rear Differential Oil)
I get about 200 miles per regen cycle which occurs when the Particulate Matter Generated (PM_GEN) reaches 6.00 g/L
Efficiency was about 28.5 mpg
Just got back yesterday from an 1100 mile trip through Ohio and the mountains of West Virginia, Pennsylvania, Maryland with just 360 lbs in the car and not towing. Burnt 31 gallons for about 35.5 mpg. Temperatures very similar to the previous weekend loaded heavier and towing...
EGT 1400 max (Exhaust)
ECT 194 (coolant)
EOT 214 (Engine Oil)
TFT 193 (Transmission Fluid)
RDT 120 (Rear Differential Oil)
Front tires run slightly warmer than the rear. (They were more even when loaded heavier and towing)
I didn't have a PID set for boost pressure. I did earlier when I first started playing with ForScan and if I recall it was about 25 psi max boost that I saw just driving around (non towing).what is your boost pressure when towing?
So on tire pressure you follow North American Mazda recommended “one-size-fit-all” 35 psi all around, not higher pressures recommended worldwide, for heavier load and towing on your diesel CX-5? ...
I've found it interesting to read of your and Coolpix99 modifications for increased cooling. I appreciate you writing about it.It seems that all the EGTs reported here are pretty consistent. @Coolpix99 reported 1382 F (750 C) max during regen which is the highest next to your 1400 F (760 C). Hopefully mine are in that range too.
I'm not an expert at this and can only tell you what I've read on google here and there. With that being said, I read this article and have been using 1500-1600 F (816-871 C) as a temperature to watch out for - EGT's Explained - How Hot is Too Hot? / Speed House Blog | Free Shipping | Best Price | Speed House
Can you tell us which version the ForScan you’re using and the link to purchase? And what kind of OBDII reader hardware setup with ForScan you’re using?the ForScan app is a fantastic tool to see a lot of information for sure!
