2013 100k Clutch Pedal Soft Overnight - Clutch Gone?
2013 CX-5 Sport Manual
I found the clutch pedal soft in the morning, especially the first half (increased free play, with grip very close to the floor). Basically same symptoms as @timberstx said in this thread.
Symptoms of my CMC going bad was too much pedal free play. And I only had to lift the pedal off the floor a little and the car started to move.
I left at [a random] mechanic, hoping it is just the master or slave clutch cylinder but they said clutch is gone. Waiting for estimate. My previous stick lasted 130k miles without clutch replacement but I did had clutch master cylinder fail on it and it did feel similar.Except I remember it getting slightly harder as I was pumping more. I don't have this feeling now but is it possible for the clutch to be really gone at 100k miles? Will the pedal feel soft suddenly overnight if is going away?
Is it possible? Sure, depending on use etc. Frankly, IMO 100 K miles is pretty good for a manual clutch. As for going ”bad” overnight, that’s odd unless it’s an hydraulic issue.
I have had cars with a cable clutch and after many miles you could tell the difference in the pedal height. It didn't change suddenly. You could adjust the cable to compensate.
Have you considered checking with some other mechanics or shops for another opinion?
Definitely will get second opinion, may be even 3rd. I have trust issues with mechanics. I had a Civic Si and was told by 2 independent mechanics that the transmission is gone (gears grinding when shifting). End up replacing the transmission oil (it was low) and drove it (hard) for another 50k miles with zero issues.
That is why I am questioning the diagnosis. I don't see any leaks yet. It is drive-ble but drastic difference from the night before. Could it be that they designed it such way so it warns you before the end of life?
Have you ever replaced the brake fluid including bleeding the port on clutch master cylinder if there’s one?
My guess is your brake master cylinder developed an internal leak overnight and an expensive replacement is inevitable. You can try bleeding the brake fluid from clutch master cylinder at first but usually it’s hard to access the bleeding port on CMC.
Apparently the clutch master cylinder on CX-5 is not built bullet-proof, and timberstx’s CMC is an example.
if the clutch itself has worn and needs replacement, it won’t happen overnight.
It should be easier and cheaper to replace the master cylinder than the clutch.
Yes, and replacing the clutch master cylinder seems to be a difficult job to me as DIYer after reading the workshop manual.
This is a good idea. I noticed the mechanic filled up the break fluid to the top. They probably tested it the system under pressure. If there was a leak, a I should start seeing the fluid drop, right?
On the other hand, I am realizing today it is not just a soft pedal but the functuanal range of the clutch is very short, meaning I have to be more presise and slower with the leg action.
Having had clutches and some of them hydraulic at that, this seems simple based on experience. First of all, a worn clutch grabs when the pedal is almost fully released (not close to the floor), and if bad enough, will slip with the pedal fully released and no adjustment left. It's a NEW clutch disc ( and hopefully pressure plate and throwout bearing) that will grab a lot closer to the floor and requires adjustment.
To simplify things and ensure future reliability, it makes sense to replace both the clutch master cylinder and the slave cylinder and get on with life lest one is replaced only to have the other suddenly fail and let you sit. The slave cylinder, being at a low point where gravity settles water, can fail due to water induced rusted bore ( brake fluid is hygroscopic) which cuts seal and causes internal leakage. The slave cylinder does not have to leak externally to be bad. Fix the hydraulics first and then see how the clutch works. I think that shop's diagnosis is a bit premature. Just my take on the situation.
⋯ If there was a leak, a I should start seeing the fluid drop, right?
Not necessary. Most of time the leak is internal inside of master cylinder, and you won’t see any brake fluid dripping and the fluid level won’t drop either.
Jmaz’s post above explained the clutch problems perfectly and your problem could also come from slave cylinder due to the rust by moisture if you haven’t change the brake fluid on clutch cylinders for a long time. But you usually can tell if the salve cylinder is failing by the sign of fluid leak around salve cylinder.
Thanks guys. I have not changed the brake fluid but it sounds like I should do it together with the master and slave cylinders change. Opening the service manual now to check complexity level (I have changed a master on Civic before).
Read the other thread by timbetstx especially the post #6 and #7 which offered his experience of replacing clutch master cylinder.
Clutch Master cylinder leaking
Apparently timbetstx didn’t replace the clutch salve cylinder. It’s up to you if you checked the salve cylinder and didn’t see any extrtnal leaks.
Changing the clutch master cylinder definitely is more involved than changing the brake master cylinder.
yrwei52 is correct about external signs of fluid leakage, which would be most of the time. I've seen the whole slave cylinder looking wet or leakage at the rubber boot on the end.
I had the exact same problem in my 2008 MX-5. The top of the pedal travel was soft and clutch engagement happened near the bottom of the travel and was abrupt. I flushed the brake and clutch fluid with fresh fluid and clutch operation returned to normal and has been normal for two years. The fluid in the clutch hydraulics was ten years old and probably degraded and contaminated with water. Maybe try that first before buying new parts.
The one time I tried to bleed my hydraulic clutch on a vehicle I instead rendered it practically useless and had to drive it to a shop by shifting without a clutch =:0
They had some kind of pump to do it. They didn't even charge me.
Did you flush thru the brake calipers only or did you do the flush at the clutch slave as well?
As I recall, I flushed the brakes calipers using a Motiv pressure bleeder and the clutch slave cylinder by just opening the bleed port and letting the fluid drip from gravity.
