Digbicks1234
16.5 CX-5 Touring/2023 CX-9 Touring
The ATF cooler adapter plate you saw has 2 ports. But don’t get confused with these 2 ports on ATF cooler. These 2 ports on adapter plate is the ATF outlet and inlet ports instead engine coolant ports found on ATF cooler. The ATF pump does feed ATF into the ATF cooler from inside of transmission to cool down the circulating fluid by engine coolant. The adapter plate provides ATF ports which are not available on ATF cooler to let fluid exchanger hooking up and exchanging the ATF. While doing that, you just let ATF cooler hang to the side by the engine coolant lines with transmission running.
Why do you want to extract old ATF through the dipstick hole? Drain the ATF through the drain hole to promote more tiny debris or dirt if any coming out with old fluid as those usually will stay at the bottom of the pan. If you’re draining old ATF through dipstick hole, the sucking power usually only stays at one area near the pan, which is not as effective sucking most of debris or dirt out. This’s similar to engine oil change. Some like to extract used oil out through the dipstick channel, so that they don’t need to go under the car. But how are you going to know you actually got all the oil out as the suction tube may not land at the lowest point on the pan, but the drain plug is.
The alternative, to drain 1 quart at a time through the dipstick and pour in exactly 1 quart, drive the car and repeat, would be worse than a simple drain-and-fill. Because once you pour in a quart of fresh ATF after you extracted one, it’s mixed with the rest of old ATF immediately in the pan, then your next quart extracted will contain some fresh ATF after you drive around several miles, which is definitely a waste on time and money. Not to mention it’s too much hassle. Do normal drain-and-fill, you for sure have about 3.75 quarts of old ATF drained, and the similar amount of fresh fluid been poured in.
Personally I’m not afraid of doing the first ATF change closer to 100,000 miles. My 1998 Honda CR-V has 75,000-mile ATF change interval recommended by the manufacture. But the risk is there as the cleaning agent in fresh ATF may wash some accumulated residue or crud off and gets stuck somewhere in the valve body, although the ATF filter should do the job to stop that.
Changing the ATF or not really depends on how long you’d like to keep the vehicle. Most people get rid of the vehicle before reaching 100,000 miles, or they’re not interested to be a DIYer, then I’d say don’t worry about changing the ATF. That’s the next person’s problem unfortunately.
Okay, that makes more sense now. I tried searching for their product on Google and I wasn't able to find anything about it aside from the datasheet containing the model #. I guess this item would be something that would need to be specially ordered.
I was thinking that if you insert the tube into the dipstick hole, it would reach into other areas that contain the rest of the fluid (aside from the torque converter) and would help in the process of extracting the fluid, aside from dropping the pan. But one good thing about going through the dipstick hole would be to extracting the fluid for an analysis since it would be less messy but that's about it.
No plans on doing the 1 qt at a time method but I was reading one of the YouTube comments mentioning that completely replacing all the fluid at once with new fluid would probably not be a good thing since all the metals that's already in there previously lubricating the transmission would be washed out. I think the basis for this claim would be that the transmission was NEVER flushed/drained before and the car is very high mileage and doing a complete flush of the old fluid would do more harm than good. Then again, it's YouTube and there's no scientific basis on any of this but an opinion so it made me curious.
I like to do what I can to prolong the life of the vehicle and also this would be a new learning experience for me as I've never performed an ATF drain/pan drop before so I don't mind.
