Me wipers on me CX5 move slowly and judder, even when raised from the windscreen.
Anybody got any ideas?
Clean the wiper blades when you wash the car. Sometimes a layer of dirt accumulates which adds friction.
2 or 3 times a year after an exterior clean I spray Wd-40 on an old t shirt and clean the portion of the wiper that comes in contact with the glass. Keeps them running pretty smooth.
Also, hitting your windshield with a clay bar helps as well. Well not actually hitting it but you know what I mean.
Even if you lift the wipers away from the glass they still move slow and jerky2 or 3 times a year after an exterior clean I spray Wd-40 on an old t shirt and clean the portion of the wiper that comes in contact with the glass. Keeps them running pretty smooth.
Clean the pivot areas of wiper arms making sure there’s no obstacles. The best is to remove the wiper arms and long plastic cover for the cowling area making sure there’s nothing to interfere the movement of the wiper mechanism linkages. The worst case is you need to get wiper motor replaced if everything else checked out alright.Even if you lift the wipers away from the glass they still move slow and jerky
It’s under warranty I hope so if I can’t fix it garage it is cheersIf the problen is presnt during all modes ie fast-slow etc, then it sounds like a motor/gear issue. If you can get the drive system out, maybe you can open it up and lube the gear train. Try to find a replacement unit or go to the dealer-Uggg. Ed
Unless there is an obvious obstruction, I'd take it to the dealer. Warranty.It’s under warranty I hope so if I can’t fix it garage it is cheers![]()
