PART 2 of pics
Anyone know if this is the same rattling / vibrating noise that plagued the previous gen CX-5?
Good luck... Hope it goes away.
So globe box area is the issue. Interestingsoulred17, I want to thank you again very much for your help and pictures. I have added foam underneath the glove box (as per your pictures) and it did help with a rattle, it is not completely gone but it is much better. I will continue adding foam as it shows in your pictures and hopefully it will cure the problem.(2thumbs)
You are very welcome.... I am glad it got reduced.soulred17, I want to thank you again very much for your help and pictures. I have added foam underneath the glove box (as per your pictures) and it did help with a rattle, it is not completely gone but it is much better. I will continue adding foam as it shows in your pictures and hopefully it will cure the problem.(2thumbs)
Its one of the problem areas
Seriously if there is more than one problem area, take the car back and get them all resolved.
Dealer claims that in order for them to try and find the issue I would have to leave the car at the dealer at least for two days so that they can take the hole interior out one section at the time to find rattle/noise, but I really do not feel comfortable letting them take new car apart.
Fair enough.
Maybe if these rattles were from day one as in as soon as you picked it up and drove it, you should have gone back and demanded a new vehicle (uhm)
