Once that had dried overnight it was on to the next step. I removed the tape on the upper piece and then taped over the charcoal. That ended up pretty much the reverse of what it had been.
I cleaned the exposed area again with alcohol and then applied primer:
Four coats of primer applied following the can instructions, after which I lightly sanded it with some 600 grit wet paper. This time I simply wiped it down with a wet rag. Then after a wait of 30 minutes it was time to apply the color:
I applied three coats again following the instructions. After another 30 minute wait the clearcoat went on. I applied four coats of clear. I let that set up for a few hours and then removed the tape. Unfortunately when pulling it off I had a couple of small chips come out:
Since I didn't want to redo the whole thing I simply used the bottle of touch-up paint with a brush I already had, it filled in nicely.
I should also note I painted all the fasteners the same color as where they are used to blend it all in and minimize jarring contrasts.
Before installing everything I wanted to replace the rubber muffler hangers. I heard some banging over bumps, when I checked the lower diffuser showed signs on contact on the driver's side:
I had to juggle some hangers around from my son's Protege and Minnie but it got done. The muffler is nice and tight now. Reflectors went into their slots on the upper piece and then both upper and lower were installed.
I already posted the end result.
