- Plano, Texas, USA
Tire Pressure Sensor for 2017 CX-5 - $91.74 EACH!!!
You may be able to get by it with rebuild kit at first set of new tires. Then you still need to replace these expensive tire pressure sensors for your 2nd set or 3rd set of tires if you plan to keep your CX-5 long.The direct TPMS sensors have a battery life of roughly 10-12 years our so and then they will need to be replaced. When you replace tires, good tire shops will have a rebuild kit that will replace the valve core, rubber washer and retaining nut on the valve stem of the sensors. You don't replace the entire assembly with each tire change. Cost is $10-15 dollars per wheel depending on the shop. Normal rubber valve stems will be around $2-5 dollars apiece installed, so you are correct in that it will cost a little more with each tire change. Maybe $30 more total.
