2016 CX-5 AWD light came on.
F1sh73
2016 Mazda CX-5 Sport AWD
Hey, guys, I was wondering if I can get advice/suggestion before driving to a dealer. Long story short - I'm the owner of the 2016 AWD CX-5 which been involved in a rear end accident. I replaced the rear bumper + had to work on the exhaust hangers (they got bent a little bit) and it was all the damage I was able to locate (except couple small marks on the liftgate, which I'm not worried about).
My problem is right now - 4WD light stays on the dash all the time (not blinking) and I'm not sure if it was like that before the accident or not. Vehicle drives fine (no slips or strange torque moments as far as I can feel).
Possibly a loose connector from the wreck. IDK how different the (if at all) the fuse setup is from the 2015, but check the 50amp fuse (should be purple) for DSC. A quick find search through the workshop manual pretty much associates loose connections/short circuits/blown fuses with that light. Is a red triangle on too?
Thank you, I'll check the fuse and will let you know.
Mmm. red triangle? No, didn't see it, only orange 4WD light (right below the blue coolant temp light).
