2017 DRL/signal light emulation
Dang son, you really have it out for these headlights! The reasoning in your post bothers me on so many levels. ***EDIT: directed at yrwei52
Since Scandinavia countries started using Daytime Running Lights in 1970's with amber parking lights due to low ambient light levels in the winter, it's getting more popular worldwide and also comes with some heated debates. For a while low-beam headlights were adopted as DRLs but eventually got phased out due to problems with glare and turn signal masking by full-intensity headlight DRLs. Many countries started limiting DRL's intensity hence car manufactures dumped low-beam headlights as DRLs, and used reduced-intensity high-beams as an alternative. The added benefit of this is the bulb life on low-beams which are used most often during the night can be prolonged as they're not on all the time. And apparently you missed the quotation marks for most of comments I posted. Those were comments from anti-DRL advocacy groups since GM started implement the low-beam DRLs in the 90's. Only the unquoted ones are my opinions.
FYI - The LED headlamp is NOT at full power in DRL mode. It is at reduced power. Pull up to a wall and play with the lights, you will see the difference in intensity against the wall. And IMO anyone complaining about glare due to a headlight being used as a DRL in the daytime is completely full of rubbish.
I don't own a 2017 CX-5 but based on short testing of DRLs from a CX-5 Touring, I didn't notice any reduced intensity on low-beam headlights for DRLs:
Here are some pictures from 2017 CX-5 Touring showing whenever DRL function is on, both LED DRLs and LED low-beam headlights are simultaneously on! You can imagine how GT DRLs work by replacing Touring LED DRLs with GT's LED Signature DRLs.
attachment.php
attachment.php
Here's what the front lights look like when light switch is at parking light position without DRL function when car is in stationary:
attachment.php
Here's what the front lights look like when light switch is at headlight-on position without DRL function when car is in stationary:
attachment.php
Finally for 2017 CX-5 Touring the high-beam is from the same LED cell for the low beam in the projector, and use a shutter to control them like 2015 bi-xenon HID. For 2016 LED headlights we have a separate LED cell at inner side of the low beam LED dedicated for high beam only.
View attachment 216512 View attachment 216513 View attachment 216515 View attachment 216514
And here's the obversation from a 2017 CX-5 owner:
A little more testing.
Headlights set to auto
Daylight outside
Pull into garage (as we all now know, headlights are already on even though it is daylight)
Garage is darker than outside
Eventually (a few seconds) green indicator comes on by itself showing that headlights have now been turned on (tail lights and parking lights also come on)
Light intensity against the garage wall does not change
So, to me, headlights are at full intensity even during daylight hours.
The only thing the auto setting does is turn on your tail lights and parking lights and dim interior lights.
Most complaints here are not for glare, but the unnecessary strong LED low-beams drowning out the nice-looking LED Signature DRLs and turn signals. The low-beams aren't on with DRL mode on 1st-gen CX-5, and on 2nd-gen CX-5 in every other regions. Why do the Mazda North American Operations want the change only for the US customers? NHTSA hasn't made any regulation changes on DRLs.
If a headlight can be used at night there is NO reason it can't be used during the day, and that's the bottom line.
Ask people with anti-DRL advocacy groups they have plenty of reasons to tell you. The same in entire Europe Union including those countries that are the granddaddy of the the DRL, they all outlawed the headlights as DRLs in 2011!
Then you argue about longevity of the headlight....
Headlight uses LEDs. Same technology as is in the "signature lighting" strips (in the top model) and individual DRL bulb in the lower model. What's the difference between using an LED in an accent strip vs an LED in a headlight housing with any DRL system needs to be on all the time and neither components are serviceable? None.... If the accent strips are used all the time and one goes out, the housing needs replaced. Same for the headlamp now. It's an unfortunate truth, but it is the price to pay for more advanced lighting.
Even in theory LED won't last forever. And most of time it's the other components failed first due to heat or quality. The headlight LED uses a lot more power than accent strip LED, which is generating a lot more heat and that is the major difference between the two. To see how long the LEDs even on accent strips can last on our CX-5 if you keep them on all the time, just see this thread:
Daytime running lights dim/flickering
With some section of accent strip DRLs flickering or failed at least I can live with it without replacing the expensive unit and pass our annual Texas state inspection. But if the LED headlights failed due to over-usage, you have no choice but replace it or you either get ticket or can't pass annual safety inspection. We simply don't need headlights with DRLs.
IMO, this is a ridiculous argument. You're saying school buses are complaining about trying to be safer? LMAO! Where is this coming from? You've gone from arguing that a DRL in a headlamp is bad to arguing that DRLs in general are bad. DRLs have been the law here in Canada since 1989, purely for safety reasons. From the exact same 14 year old report that you linked to are the figures the author used to advocate for the use of DRLs:
I'm not against DRLs. I'm against the low-beams been used as DRLs. Nobody uses low-beams as DRLs as it's unnecessary with new LED accent strips serving as Signature DRLs beautifully and nicely. Please name any one car model among all new cars selling in the US other than Mazda which is using low-beams as DRLs when it already have dedicated LED (or Signature accent strips) DRLs ⋯
If this happens it is the driver's fault, NOT the car's! There are other ways to know that headlamps are on or not at night time including, but not limited to: changes in dash illumination (either becomes illuminated, or if it is already illuminated it becomes dimmer), headlamp indicator in gauge cluster if gauges are always illuminated, the fact that whatever light projected forward from the car is not typically sufficient for night driving and the driver should recognize something isn't right.
If the low-beams are not on with dedicated LED DRLs, this human errors can be mostly eliminated. And which way is safer? We don't need to agree everything Mazda designed and configured. Besides, this is not from Mazda itself, but from MNAO!
The OP's original concern is visibility of the turn signal. The only relation to the DRL system at all is the fact that the DRL "signature" lighting illuminates the same area of the light housing at the same time of the turn signal, potentially reducing visibility of the turn signal.
If anything will come from the original concern in this thread it will be that Mazda devises a way to turn off the DRL adjacent the turn signal when the turn signal is turned activated which some other manufacturers already do. I'm not sure if that is a mandatory requirement due to a regulation somewhere or if that is voluntary (my assumption) but for whatever reason Mazda didn't have to do it so they didn't. If they had to do it to satisfy some regulations, it would've been done.
Here's a link explaining what I mean. Ironically this link also says why I believe the headlight itself is a part of the DRL system... because the headlight is the DRL (as it is brighter) and the lighting strips are the "signature lighting" that happen to work along side the DRL.
http://jalopnik.com/heres-why-modern-cars-turn-off-one-of-their-lights-when-1792394567
At least in the US where this article comes from, it appears that Federal Motor Vehicle Safety Standard 108 is what would require the DRL to be deactivated when the turn signal is activated.
Here's a specific requirement from that specification which applies to the CX-5.
I'm assuming as I don't have the headlight system output numbers, Mazda was allowed to use to keep the signature lighting strip / DRL illuminated next to the turn signal as one of the following exceptions applies to their design (at least in NA). The signature lighting isn't bright enough to be considered an issue, or the turn signal is bright enough compared to the DRL that it isn't considered an issue, as exemption C does not apply to the new CX-5's design:
I tend to believe that if you are in the US and you have concerns with the signature lighting / DRL / vs turn signal the above regulation is where you have to start arguing your case.
Now we're talking. European Union Directive 2008/89/EC requires all passenger cars approved on or after 7 February 2011 in the EU to come equipped with DRLs. And functional piggybacking, such as operating the headlamps or front turn signals or fog lamps as DRLs, is not permitted. That's why we see so many Euro vehicles and any car models exporting to EU turn one side of DRLs off while the turn signal is on. Like the article you provided said, US has similar regulations for this but there're exceptions. That's why we see 1st-gen CX-5 configured the way without turning the DRL off while the same side of turn signal is blinking although they're from different light sources. MNAO can easily meet the first exception without the low-beam headlights on like the 1st-gen and the 2nd-gen in all other countries even if our 2017 CX-5 doesn't meet FMVSS Standard No. 108's 100mm spacing rule. This also saves Mazda's production cost without designing and manufacturing a special DRL system only for the US!
The luminous intensity of the DRL is not more than 2,600 cd at any location in the beam and the turn signal lamp meets 2.5 times the base front turn signal photometric requirements
BTW very nice article from your link, and sorry for the very long reply. (drinks)
This is going way off topic from the OP. So I'll just make it quick and not come back to the whole DRL thing in this thread.
Headlight intensity is higher than DRL intensity. It is this way in Canada on my '17 Mazda 3 which has the LED headlights / DRLs. I haven't put the new CX-5 up against a wall to test it myself yet but I have a hard time believing it's any different.
1 Other car the same way? Toyota Carolla with LED headlights also use the LED headlight at a lower power level as DRL. For the sake of comparison, the Carolla also has the turn signal right next to the headlight and inboard of it but I can't recall if they shut off their DRL with the turn signal.
https://youtu.be/6R7d0N6ODBE?t=42s
Also a truck: F150 with the LED headlights. You can see it here using it's turn signal not shutting off the DRL.
https://youtu.be/v-GqBcN5mdo?t=10m57s
I'm sure there's more but I'm not spending time looking into it
I thought the topic of this thread is related DRLs? (uhm)
Anyway 2 examples you presented have no "dedicated" DRLs but using low-beams as DRLs. Our 2017 CX-5 is different. Sport and Touring have a simple dedicated LED DRLs between parking lights and headlights as seen in the pictures I posted earlier. GT has LED accent strips serving as Signature DRLs. No need to add low-beams for DRLs!
Response from Mazda NA:
Thank you for your email.
There is a helpful chart on page 4-52 of the owner’s manual that will show you the options and the conditions when the headlight will be on.
If as stated in your email the headlights are always on when the vehicle is moving, even if the headlight selector is in the OFF position, then your vehicle is not operating within factory specification in which case we recommend diagnosis by our technicians at an authorized Mazda dealership.
Here is the closest dealership based on your zip code:
Thank you again for your email. If you have any questions in the future, you can reach me directly using the number and extension below.
If this is the case, then every single GT in USA will need to be taken to a dealership (uhm)
I have tried to explain to them that the actual headlight is part of the daytime running light setup for some reason, different than both Japan and Australia, but no luck with them understanding so far. Even though DRL's are not required here, I believe we may be forced into this setup because of Canadian requirements. That is the only reason I can think of.
Only way to explain it to them is sending them links to you tube clips showing how it works here in OZ and Japan then see what they say
Just to be clear that video is showing the parking lights, not DRL mode. Can tell by the indicator on the dash as well as that the tail lights are also on.
Yrwei52: On my 2017 CX-5 GT (US), there is definitely a difference in headlight brightness between DRL and ON. It doesn't appear to be a large difference from inside the vehicle or by looking at the reflection in a window, but it's definitely there. It would be interesting to see the difference from an oncoming car.
Normally when headlights come on, DRL decreases in brightness a little bit. But since you guys have headlights on all the time, maybe the headlights do change brightness
Thanks for confirming that I'm not the only one that sees it. Our's is the same as well in the GS/Touring headlight config.
It is my personal belief that the signature lighting and the secondary DRL element in the Touring lights are there purely for styling purposes and it is the headlight in a lower power states that satisfies the legal requirement for the DRL - at least somewhere in NA.
I bet the secondary bulb in the GS / Touring headlight is so dim to get around the rule of having to turn the bulb off when using the turn signal, and again possibly also for appearance reasons. I for one am pleasantly surprised by how they look on the road.
I believe that the headlight in a low power state has to be used as the DRL here as there is likely a brightness specification somewhere that the signature lighting on its own, for whatever reason, can't meet. This makes sense to me if the DRLs are dim enough to remain on with the turn signal activated. However, it is purely speculation on my part as I am no expert in the design regulations.
Bottom line is it is what it is - whether intentionally designed that way by Mazda purely for appearance / styling purposes or to meet legal requirements due to a technical limitation of the chosen headlight hardware.
The only thing that can be realistically be done to improve the visibility of the turn signals is: turn off the DRL when the signal is activated; or add another turn signal elsewhere. At this point I would say it would go down near the fog light area to avoid any bodywork similar to the Mazda 3. However there would have to be a serious issue proven to force Mazda to do this at this point as it won't be done voluntarily. Then of course there's the option to do this yourself if it's something that bothers you that much and you already own the car.
With that said, it seems to be a perceived issue and not a real issue as the design has passed requirements around the world - at least anywhere where the CX-5 is currently being sold.
I still haven't had an issue seeing any front indicators on the new CX-5 in real world situations on the street - they're not everywhere yet but they're starting to pop up on the streets. Sure you can't see the left signal from the right side of the car very well, but you also don't really need to.
I don't disagree that the Touring / GS model will have a slight visibility advantage because it does not have a light strip overlayed on top of it.
I don't think its weird that the headlights are being used in a lower power state with or as the DRL. But I do think it's a little weird that Mazda chose not to turn off the DRL adjacent the turn signal when the signal is in use, even voluntarily if they weren't required to.
Has anyone with concerns over it actually contacted Mazda to gather their thoughts?
My $.02
Here is a quick quote from the US Federal Motor Vehicle Safety Standard 108.
Each DRL not optically combined with a turn signal lamp must be located on the vehicle so that the distance from its lighted edge to the optical center of the nearest turn signal lamp is not less than 100 mm...
Exception:
(a) The luminous intensity of the DRL is not more than 2,600 cd at any location in the beam and the turn signal lamp meets 2.5 times the base front turn signal photometric requirements
Sourced from http://jalopnik.com/heres-why-modern-cars-turn-off-one-of-their-lights-when-1792394567
Why can't Mazda just turn the DRL off when signalling instead? Or how did they skirt around these rules?
This is something I have yet to see on the CX-5 here in Aus. ie. do the headlights come on together with the DRLs and whether the DRLs turn off when indicator signals are flashing. In the CX-9, the signature DRLs do turn off on the side where the signal indicators are on and the headlights don't come on with the DRLs during the day either. Hope its the same in the CX-5.
Turn signal is a separate bulb to DRLs and headlights.
Even so hopefully the DRLs fully dim or are off when the signal indicators are on or wishful thinking perhaps.
DRL's more than likely will stay on and not dim.
They don't change at all in my current Mazda6 except when headlights come on in which case they dim
For Pipemajor and others:
Was scanning Youtube and found a 2017 CX-5 owner who has installed a VLEDS Triton LED for their right (when we view but left for car) indicator:
Pipemajor is changing his turn signal bulbs to a more brighter ones
Sent from my SM-G935F using Tapatalk
Is it possible? I was under the impression that the whole headlight assembly of the 2017 CX5 has proprietary bulbs that cannot be changed signal lights included.
Sent from my ASUS_Z012D using Tapatalk
