All the Parts P5 Part-Out Thread
***ITEMS STILL FOR SALE. THREAD UP TO DATE***
So, here's everything I've got (the car is gone). Prices includes shipping to locations in the USA unless otherwise noted. I'll do some combo discounts and will consider reasonable offers. I've tried to organize this so things are easy to see, so keep scrolling all the way to the end of the post! If you have a question or want a clearer picture, hit me up and I'll see what I can do. Parts shipped from 46256 (NE Indianapolis), local pickup available on request. I'll try to ship within the next business day if at all possible. Paypal is JonathanSGroves@gmail.com. No dibs, first with the money gets the goods. The best way to contact me is PMs here on the forum. Enjoy!
Signature Sound Coolant Tank (a few corrosion spots) $OLD
1.8L Coil (used but works well) $OLD
RR Racing UDP (Underdrive Crank Pulley) $115 *PRICE LOWERED
Bolt Caps $5 or free with purchase
Fiamm low-tone horn $OLD
O2 sensor extender $15
626 Valve Cover (some chipping and surface corrosion, but looks relatively good) $OLD
Mounting spacer for Optima Battery $10
Hawk Rear pads P5 (may fit other models, check before purchase) HB436F.535 $50
*PRICE LOWERED
Purolator PureOne PL14610 (larger oil filter that fits P5)
$OLD
P5 Spoiler (in good shape, a few scratches and on small clearcoat spot pictured) $OLD
P5 upper grill $OLD
P5 tails (bluebatmobile turn signal overlays, can be removed, bulbs and tails included) $75
P5 Headlights (complete, no broken tabs, high beam bulbs included) $OLD
P5 Speedo (approx. 125K miles on the odometer, ODO is readable but has damage) $65
Gauge cluster surround $40
Turn signal stalk with fog switch (MPV), P5 turn signal, P5 wiper control $20 each
Driver*s door switches $35
Lock button with bezel $OLD
Cigarette lighter $OLD
Cargo bay light (with bulb) $15
Rear window switches (2) $10 each
Dimmer control switch $15
Fog Switch $15
Switch Blank (1)/Coin holder switch blank (1 remaining) $5 each
Shift boot (slightly worn on top but in good shape) $15
Tweeter speakers $OLD
Sunroof controls and map lights (bulbs included) $40
Ebrake surround $25
Ashtray $OLD
Cupholders $30
Armrest door/cover $OLD
OEM in-dash 6 cd changer make offer
MSP radio pocket with support bar $OLDScosche Radio pocket $20
OEM Airbox/intake (3 pieces together) $OLD
Stock 2.0L Valve cover $OLD
Set of 2.0L Coils $30
OEM Crank Pulley $20
Throttle body $65
Front Left brake caliper $30
Power Steering Pulley $45
Dirty EGR Valve $30
OEM Strut tower brace $OLD
Misc sensors and solenoids
$OLD IAC, $20 each others
ABS Sensor $OLD
02 sensors (VERY dirty) $OLD
OEM shifter with hardware and bushing
$35 shifter alone, $15 hardware alone, $45 both
OEM Horn (sucks) $5
Crank bolt $5 or free with crank pulley
Full set of OEM exhaust hangers $15
EGR Pipe $OLD
Coolant tank brace $10
P5 Manual ECU FSAE-18881-A $85 *PRICE LOWERED
Stock coolant tank (no cracks) $20, or tank and bracket for $25
Battery tie down & rod $OLD
Seatbelt guide brackets $20 each, $35 for the pair
Seatbelt roll with bracket and hardware $40
Rear seat buckle pair $15
Front license plate mounting kit $20
OEM Radio Antenna $10
Glovebox (complete) $60
Interior handles from all 4 doors $OLD
Headrests $OLD
Received the tweeters today, thanks. My car does not have the wiring but they will get installed sometime soon.
