I could believe they are equivalent, dealer mark ups on parts are ridiculous
Didn't know there's a "mini" van which is equivalent to now defunct Mazda5 with a SkyActiv-G engine in there! Wish Mazda actually offered Mazda5 with SkyActiv Technology to the US customers.On this picture of the PE5R-18-110 OEM parts box we can see the NGK # ILKAR7L11
Here is the ILKAR7L11 plug on amazon...
https://www.amazon.com/dp/ (commissions earned)
The only other application I am seeing listed for these plugs is a NISSAN LAFESTA HIGHWAY STAR, which interestingly enough, is simply the MAZDA5 Van, with the Skyactiv motor that Mazda sold to Nissan that they rebadged and sold.
This is not completely true, it will vary from dealer to dealer. But, most of them have higher percentage mark-ups on lower price items - their justification being that they still have to pay the labor, storage, and cost of money for the products being sold.I agree the markup on OEM parts is high, but the markup percentage from their cost is always a fixed number. The price on Mazda OEM oil filter and moly oil are not much higher than aftermarket oil filter and Castrol oil. The cost of Mazda plug must be high for a reason. They won't simply mark up 300% from their cost only on spark plug!
$80 for brake fluid flush and oil change is indeed an excellent price! Have you found out what kind of oil your dealer uses? And have you decided what kind of spark plugs you're going to get? Getting these plugs online is the cheaper way, such as from Med Center Mazda - our sponsor for genuine plugs. NGK plugs are the legit alternative. It's not too hard to change spark plugs, but make sure you don't want to over-tighten the plugs and strip the thread on cylinder head!Thanks everyone for your suggestions! I did get the brake fluid flushed today for $80 at the dealer with some coupons and discounts. They said they would flush at each caliper. And they also gave me a free oil change. Overall, seemed like a very decent price. I would however change the park plugs myself in the next few days following the guidelines provided here:
http://www.paulstravelpictures.com/Mazda-CX-5-Skyactiv-G-Engine-Spark-Plugs-Replacement-Guide/
It doesn't look too hard. Now I need to get the tools and parts.
Actually the next thing I'd do in your situation is drain-and-fill ATF with OEM Mazda ATF FZ. You can wait a bit on spark plug replacement until 75,000 miles.
Forgot to ask what kind of oil they used. I will ask them the next time I go for oil change.
I was thinking of NKG, but i will look into your suggestion.
Other things will follow soon after. So far I do not have any tool, but I am fairly confident that I can do these maintenance myself...provided decent instructions. Do you have any suggestion for tool box? Buying them individually will cost a lot more I guess.
Sent from my iPhone using Tapatalk
Chris_Top_Her has given you the best suggestion getting some basic tools for DIYer with a CX-5 without spending too much money, especially when the Black Friday is coming.⋯ Other things will follow soon after. So far I do not have any tool, but I am fairly confident that I can do these maintenance myself...provided decent instructions. Do you have any suggestion for tool box? Buying them individually will cost a lot more I guess.
just did my first oil change, and agreed with other CX-5 owners : the easiest oil job ever.
one question, did anyone do this without ramps ? I tried but there wasn't enough space for me....
only hiccup was I had a very hard time getting the old aluminum crush washer off the drain plug flange, it was really stuck on there, I had to use an xacto knife blade to separate the old crush washer from the drain plug.
note: I can easily see for any first timer to think that there is no crush washer or if they lost the crush washer when it's actually there stuck on the plug flange, I thought the same thing it looked like one piece and the crush washer was missing, but when I compared the new crush washer supplied by Med center Mazda versus the drain plug, I can clearly see the crush washer stuck on there. I used a miniature flat blade screwdriver but that didn't work so I used an Xacto knife to get that damn thing off. I hope no one doubled up on the crush washers thinking the original crush washer was part of the drain plug.
everything was exactly as other posters have said, drain plug is a 8mm hex socket type, so you'll need an 8mm allen key to loosen the plug, and make sure it is inserted all the way into the drain plug before turning. I recommend using a high quality high torque type, don't use those you find at dollar stores, I brought mine from McMaster, it is very high quality made by Wera Tools
McMaster p/n 57185A28 $2.54
https://www.mcmaster.com/#57185a28/=14t9trr
Also, I used Lisle 63600 oil filter tool, highly recommend this, it's idiot proof, only works one way (allows you to loosen only, when installing new filter, hand tighten only don't use wrench) https://www.amazon.com/dp/ (commissions earned)
like others, I decided to stick with what came with the car and use Mazda moly oil bought from our forum sponsor Med Mazda sold as a set: 5 qt. 0W-20 moly oil, Mazda oil filter, and crush washer
not sure if it matters, but I also pre-filled the new filter with new oil just to make sure when I re-start car there's no oil flow void....
with regards to crush washer, I noticed there was a smooth stamped side and a sharp edge burr side due to the stamping process, I made sure the smooth side is up against the oil tank to prevent scratching /rusting
for those interested, here are the p/n's off the packing list:
oil filter : PE01-14-302A
crush washer: 9956-41-400
Can you confirm the p/n of your OEM oil filter from Med Center Mazda actually is 1WPE-14-302 from Thailand instead of PE01-14-302A from Japan? I just got an OEM oil filter from my Mazda dealer and Mazda parts system has superseded Japan made PE01-14-302A to Thailand made 1WPE-14-302.
1WPE-14-302 oil filter ???
We appreciate your detailed oil change write-up with many pictures and a picture is worth a thousand words! BTW, I use Craftsman ⅜" drive 8mm hex bit socket for drain plug so that I can conveniently use a ratchet or use a torque wrench if I want to.
