- 2016 CX-5
Not a big fan of the OEM double horizontal bars bezel above the foglights so I removed them and
Installed fog LED bezels $45/pair (ebay) in 2016 CX-5, these will not fit if you have the LED fog options, the diameters don't match
http://www.ebay.com/itm/252337460742?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Removed 2016 OEM fog bezel and replaced with CX-5 LED bezel :
no shroud HID foglights from Mazda2 ebay:
http://www.ebay.com/itm/Driver-Passenger-Sides-Fog-Light-Lamps-w-Halogen-Bulbs-For-Mazda-2-3-6-CX5-CX7-/381487977533?hash=item58d274943d:g:vvcAAOSw8-tWaN0J&vxp=mtr
they are properly aimed so there's no glare
these really light up the ground unlike my friend's tiny little 2016.5 LED fogs (those are laughable, hardly any illumination),
Installed LED switchback, need to install load resistor unless you don't mind hyperflashing
http://www.ebay.com/itm/231616765854?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
need to remove 3 panel fasteners and bend back wheel well plastic panel to access front turn signal bulb
video of switchback LED, these are the newer generation switchbacks so there's no white light when the yellow light flashes, the white light comes on like 2 or 3 seconds after the yellow light stops flashing, the white light does not come on at all when the yellow light flashes which is what most drivers want unlike the previous generation switchbacks.
