Please keep us posted. It'd be interesting if this serpentine belt tensioner is covered under powertrain warranty. They can always say this is a wear-and-tear item.Looks like my surpentine belt tensioner is starting to weep a little. 55k and change on the odometer. Hopefully it's something covered under the powertrain warranty if the dealer thinks it's bad. Got an appointment for next week.View attachment 214584View attachment 214585
Please keep us posted. It'd be interesting if this surpentine belt tensioner is covered under powertrain warranty. They can always say this is a wear-and-tear item.
Didn't check. Besides, that's for belt wear, shouldn't have anything to do with the tensioner starting to leak, no?Is the wear indicator close to the end?
Mine was completely collapsed and had been for a while. I didn't realize it was malfunctioned until my rarely used ac started squeaking. It had probably been busted for 10000 mi at least. The belt was changed too.
If it's starting to collapse it might get close to the limit. Also curious to see if the belt wears at the same rate as the tensioner.
Would this be Part #2 in this illustration? Essentially part of the alternator. Looks to be a $100 part if its part# PE0315980B. Might as well change the belts too.![]()
Just about ask the same question! In Texas summer the air from outside is warmer than your body temperature, you can only feel the hot air blowing into your face if you leave the window open which is not comfortable! Must be a few ones I know really enjoy the hot weather!Interesting... Dude, you don't use your AC in Texas???
Very rarely. Generally if its less than 95, I can enjoy the window down roof open. I prefer to have my windows open because I like the open vs cooped up. I spend enough time indoors at home or work. I fly with the window open on the cessna sometimes too. If I start getting sweaty I'll close It though.
Looks like it's near the last markView attachment 214593
Looks like an easy part to change... I know those sure make changing belts easy.
