What do you mean by that? I'm sorry, I don't follow. You had to put your WHAT halfway into WHAT? (dunno)
Also, can you send me a link to that oil drain fitting?
Look at the pic in the link I sent. Closely. Then look at preferios.
The fitting is 3/8npt 45bend and a 3/8npt to 5/8 hose barb put together.
Preferios is closer to what I'm gonna do, but he used the factory oil drain fitting on the MBSP.. I'm planning on tapping a M12/1.5 - AN-10 and then running that to the turbo drain, like Preferios... but with a 626 MBSP so I don't have to block the factory MSP drain hole. Clean and proper. Hopefully
when i put the msp back togehter i installed the pope downpipe and stock oil return. no problems at all. the silicon tube used can handle quite a lot of heat.
The motor is finally in 1345, it's all downhill from here. Going to try to install the ZE intake, accessories, and possibly the Pope DP/turbo today. The rear motor mount hole wouldn't line up so I gave up late last night but I will hopefully be able to get it today, even with a jack and the other mounts loose I couldn't get the damn bolt through
I've driven the msp more this week than the last 6 months combined and two issues have surfaced.
1. The heater core is mostly plugged and slowly mixing rust and crud into my coolant and passing the occasional bubble that's causing heating issues. I'm going to have to drain the coolant and aggressively flush the core to clean everything up...
2. The car hates its accessory belts. The PS belt refuses to ride nicely (it was thrown completely off on the highway today) and the alternator belt has a ragged edge that tells me the crank pulley might be the source of the issue. There's only one thing both belts have in common so I have to pull my crank pulley and give it a thorough check over. Maybe its time to get a hydra and see if that cures the issue.
Other than these issues, its fast, fun, and relatively quiet. I'm dialing in the tune and I think I'll see 375 at the wheels at about 19 psi when its all said and done. What could a gt30 and some cams do??? 450-500 at the wheels sounds completely useless but it would be fun to bench race. Its crazy how fast cars have gotten in the last few years. A front driver with over 300 hp was a really fast car 10 years ago. Now unless its 500+ its just a footnote.
Indeed sounds like a maga flush is in your future. My old school mechanic told me to forget the over the shelf products and just use Cascade dish washing powder. Running it for a hundred miles or so then flush it real good.
Hydra crank pulley sounds like a nice addition :-)
375 sounds like a lot of fun. We're are still waiting to hear what a P.E.P exhaust sounds like.
Sent from my HTC Desire 626s using Tapatalk
What turbo are you running?
I had that issue a few months ago on my old built engine. It would look to be tracking off by one rib or so then eventually work it's way out another rib. Could not find evidence the crank pulley was causing the problem. I even went so far as to considering the the crank walking, but when I tore it down last weekend, the thrust bearings weren't worn excessively. Power steering pump shaft didn't have any in and out movement either. The engine is completely new, but I am reusing my power steering pulley and (new) belt. We'll see if it continues.
I'll get some video the next time the car is out. Based on the weather it will probably be at least a few days.
I'm running a disco potato so I'm going to be just about maxing it out at 375 wheel. A gt30 in a t2 frame is increasingly interesting to me.
At least I'm not the only one with the stupid belt walk problem. Mine walked about 2 ribs almost instantly and then stayed put for 450 miles. I've tried every trick I can think of... I'll probably just pull the trigger on the crank pulley. 4 lbs of mass off the crank sounds good and will go nicely with my 11 lb flywheel. The car should rev like mad.
And you're using a Unichip, Tom?
Yep, the q+ - I like a lot of things about it and there's no doubt I could easily run 1000+ cc injectors and fuel just about anything. There are only a couple downsides to it versus a standalone. There's a lot of wiring I would love to dump, but I don't want to stare at a check engine light. I'd also like to go COP with some hotter coils. Aside from that I still have a fully functioning OBDII port, I don't have to tune idle, cold start, hot start, cruise, etc, and the install took 20 minutes rather than the 10 hours I spent building a custom harness for the KL-T swap I did.
With orange virus cracking the ecu. You might be able to dump the extra wiring.
I just popped over to Hydra's site to order the crank pulley and they're out of stock. Maybe I'll do some CAD, get some stock, and cut one myself. I'd have to buy a broach though. Is anyone else making crank pulleys?
oooh cracking the ecu would be fantastic news!
spent some time on the racing harts i brought back from maple ridge. the faces were pretty good but the lips were really mangled. no matter. got them blasted, etched and sealed with surfacer, filled rash and sanded.
i have to say that anyone looking to do wheel repairs or pretty much any kind of precision sanding should steer clear of the rotary tools or die grinders and go straight to a ocilating tool..
i picked up a dremel multi max mm 30-04 whcih had the 3.5 amp motor and made short work of the bondo sanding. WAAAAY easier to handle compared to a rotary tool and gives a nicer flatter finish.
I had a fein at work, but thats a $800 tool vs the $120 dremel heh. save the fein for fancy woodwork lol...
Guy is still trying to sell his on the parts page. Plus I'm sure they can whip one up
Well last night I got some work done. I dremeled down the casting marks on the block side of the inside of the water pump housing, installed the water pump, idler and tensioner pullys, and I finished porting the oil filter relocation block off plate. Ordered seals for the WRX 440's and its time to start up the injured motor and pull the fuel pump relay so I can start pulling parts off the actual car.
Gonna pull the head, intake, and throttle body and bring it over to the 626 bottom and get that mounted up.. I would like to get the whole motor assembled on the stand to be honest. We'll see if I get to the turbo assembly. I will do as much as possible before I tow the car to work probably next weekend or the weekend after that. My Bday is the 19th of May.. it also marks my 1 year anniversary with this car, so I'd like to drive it. lmao. Take her up to make-out point or something..
lmfao
Put the intake mani on after engine swap. Will make hooking up the alt branch and rear motor mount way easier. WAY easier.
Yeah.. you are 100% right about that. I guess if I can get the head on, all the timing done, get the water block on there, and the exhaust mani / turbo brought over, that will be a good enough "head start".
How much difference am I gonna see if I switch 5th gears out of this Probe tranny? Should I even mess with it?
