I'll get some video the next time the car is out. Based on the weather it will probably be at least a few days.
I'm running a disco potato so I'm going to be just about maxing it out at 375 wheel. A gt30 in a t2 frame is increasingly interesting to me.
At least I'm not the only one with the stupid belt walk problem. Mine walked about 2 ribs almost instantly and then stayed put for 450 miles. I've tried every trick I can think of... I'll probably just pull the trigger on the crank pulley. 4 lbs of mass off the crank sounds good and will go nicely with my 11 lb flywheel. The car should rev like mad.
Yep, the q+ - I like a lot of things about it and there's no doubt I could easily run 1000+ cc injectors and fuel just about anything. There are only a couple downsides to it versus a standalone. There's a lot of wiring I would love to dump, but I don't want to stare at a check engine light. I'd also like to go COP with some hotter coils. Aside from that I still have a fully functioning OBDII port, I don't have to tune idle, cold start, hot start, cruise, etc, and the install took 20 minutes rather than the 10 hours I spent building a custom harness for the KL-T swap I did.
