Mazda2 1.5 - Greece
Did you have to make a adapter to fit the caliper?
Just watched some of your track driving. Very nice driving, you are really pushing hard in the corners. What exhaust set up are you running?
Very cool! Badass choice for a brake upgrade. Sweet videos too!
Thanks.!
The caliper and brake lines are bolt on. I only had to fabricate the center ring for the rotors and drill 4x100 pcd holes.
They have VERY good performance even with the oem Ford EU-spec brake pads. I'll be replacing them soon with something more agressive(ds2500,1144,project μ) thought.!
The exhaust setup currently is 4-2-1 header (38mm-42mm-48mm), 200cpi cat, 48mm pipe with custom mid and rear silencer. I may change to 50 or 54mm pipe and silencers soon.
