Im planning install a sub amp to my cx-5 but then I noticed something about our Bose system. When the Fade is set all the way to the rear, there is still some bass coming from the front door 9" woofers. Can anybody else with a Bose system confirm this? Maybe thats why there isn't a subwoofer in our 16 CX-5's because Bose decided to use front door 9" woofers as a subwoofer alternative.
If this is the case, the rear speaker wires would be a bad source to tap for the LOC. Since the Bose amp has sent ALL the low frequency sounds to the front woofers. Like others have done earlier in this thread, tapping the front woofer wires should give a much better signal for the sub amp.
