I just got mine done, but I lost my USB drive, so I can't test the functionality yet.
Anyways, I have a question regarding the module part number.
In the TSB it states the part number is: GJR9-66-DH0Z. Is that the new part number or the older, broken part?
Here's my ticket saying they replaced the module:
And when I look at the new module it's showing part number GJR9-66-DH0Z:
The odd thing is it has a date on it of 6/19/2013, and the part number sticker looks like it's tacked on over an old one. The TSB does say to "use an exchange unit" so is it possible that they are refurbing older units to upgrade them to the newer model number? I did the software lookup and my module is running version 7.0.
TSB 04-001/15
US 2014 and 2015 CX-5's with touchscreen radio...
It seems they are just replacing the entire HU's now with a new model? I'm wondering if it's another patch to the problem, or if it's an entirely new head unit.
Of course, this is just a bad April Fool's Day joke...
When you quoted my post, did you read what you quoted? All of it?Do you have further information about this TSB? I can't find anything about it.
Seminole, where is the bluethooth module located? I want to check mine too to see if it's a refurbished unit.
Behind the glove box. Remove all your stuff, squeeze in the sides, and pull it all the way down. Module is mounted behind it.
I dont think head unit recognize any usb that is 3.0. Its for 2.0 only. Correct me if I am wrongThanks to CJnum6 (post #108 above) for listing the limitations of the fix. Even with the limitations I'm also pleased with it (had it done last week).
To Senor Valasco: No, you do not need a playlist for it to resume.
Does anyone know what limitations (if any) there are on the USB flash drive & contents? I used a generic 2 GB drive to test with, and it worked fine. With just 238 songs it only took about 30 seconds to load.
Then I tried a PNY 64GB drive with USB 3.0 formatted as FAT32. I loaded about 8200 songs on it, organized into folders by artist and album. It wasn't recognized at all. When I plugged it in the light on the drive blinked a few times and then nothing. The USB tab on the head unit stayed grayed out like there was no drive inserted. Just wondered if there was some sort of limit on files, folders, etc. I'm going to experiment some more with fewer songs and folders but thought someone here may know something I don't.
I've had no luck with 64GB flash drives. 16 and 32GB both seem to work.It wasn't recognized at all. When I plugged it in the light on the drive blinked a few times and then nothing. The USB tab on the head unit stayed grayed out like there was no drive inserted. Just wondered if there was some sort of limit on files, folders, etc. I'm going to experiment some more with fewer songs and folders but thought someone here may know something I don't.
Anyone know what the cost of this part and replacement would be? It's really BS if I have to pay for this being out of warranty. I reported the problem within a week of buying the car brand new. Meaning, the problem existed while it was still under warranty. I have to think I could fight Mazda on this.
Just to clarify something on the USB resume...do you need to be using a playlist for it to resume from where you left off? I generally just play albums at a time.
