It looks nice, I like it.
The tires(tyres-I always wondered, why they are spelled differently, here in the states), don't stick out from the car?
Good point, and on that note, I do rotate my tires back to front. And to be honest, both sets of Toyo Proxes I've owned have worn very well for being lowered. I only replaced the first set mostly because they were lower profile and had too many patches (on like 3 of them lol). My next wheels will be Hancook.. I have a plan for them.. stay tuned (breakn) I'm gonna buy new wheels first though, since my current tires will fir on them, but I will be getting a wider tire shortly after. Keep an eye out I will soon be selling a set H&R springs (within 1-2 wks my BC's are in the mail from ROC), a set of 5 wheels TSW mallory 20x8.5 (yes, a spare wheel included, with some paint damage from gravel.. but not bent 2-3 wks) and then 20/255/45 tires shortly after that. Also the hitch is still for sale, I have it all ready to go with all the parts.It may not be a cross rotation, but rotating front to rear is still better than no rotation at all. rotating front to rear can still provide more tread life and even out some feathering or cupping. Also, keep in mind, an AWD CX-5 is still primarily a FWD with rear drive kicking in only under certain circumstances. It's not the same as full time AWD.
I'll measure the actual drop tonight when I get home in case you're interested (I took some "before" measurements prior to fitting them).
I
On a related note, has anyone noticed the auto-leveling headlights point down more after lowering? They are supposed to adjust automatically for passengers and load in the trunk, so I think there must be a sensor on the back axle that is causing this. Is there any way to recalibrate it?
Got my 20's installed along with the Eibach ProKit springs:
Wheels are CSA Emotion (which are basically a Vossen CV5-style wheel without the exorbitant cost) in 20x8.5 et35 (F) and 20x9.5 et45 (R). Tyres are Achilles Desert Hawk UHP in 245/45r20 (F) and 275/40r20 (R).
I went with a staggered setup mainly for looks, but I'm happy with the ride and handling as well. Ride quality is very close to standard, with excellent small-bump compliance thanks to the progressive rate springs, while larger bumps (such as speed humps) are handled with slightly more firmness but certainly not uncomfortably. There is marginally more road rumble than before, but that's probably down to my choice of tyres versus the stock Toyos, which are more comfort oriented.
The big difference is in the handling, which feels much flatter through turns and under brakes, while also providing noticeably more lateral grip. I was initially concerned that a staggered setup may result in excessive understeer, but that doesn't seem to be the case at all. I even tried to provoke understeer by pushing it hard through some tight turns, and the handling remained well balanced. Overall the car feels more planted on the road and encourages you to have a go through the turns, which is great fun.
Of course the main reason I bought the wheels was for looks, and I am quite pleased with the way it has turned out aesthetically. The wheel design is quite conservative, but the fat rear stance gives it an aggressive edge that helps it to stand out from the sea of skinny-wheeled CX-5s. I'll post some more pics when the weather improves (it was dark and overcast when these were taken).
I thought that looked like more than a 1" drop, especially in the front. The rears look more similar to the 1.75" drop of the H&R Sports. For those here considering going with Eibach rather than H&R, keep in mind the difference between the two is that the H&Rs level the car by dropping it 1/2" more in the rear while the Eibachs will maintain the factory stance (higher in the rear) with the same drop front and rear. Personally, I like the level look better. BTW, H&Rs are progressive rate too.I took some "after" measurements and it turns out the drop is 40mm (1.6") all round with the Eibach ProKit springs on my 2016 AWD GT 2.5L Petrol. That's quite a bit more than the advertised 25mm drop, but I'm not complaining!
The sensor is located on the left rear control arm. I'd imagine you could add some spacers/washers under the bottom bolt to compensate.
Perfectly good !!! I`m curious about my stands ! Within two weeks I`ve the same look`s of the CX-5....Eibach Pro Kit with TSW Sochi 8,5 x 20 245/45/20 (although F + R) a little bit smaller but I`m very surprised that the Eibach Kit is 40 lower than the specs from Eibach......they said 2,5 !!! I`ll think I can live with that !!! (nana)
Awesome, thanks for that. Has anyone tried manipulating this?
Good, are you saying you are seeing a difference/having an issue with the auto-leveling feature of the headlamps (ie throw distance not what it used to be, etc)? Or are you just curious if the auto-leveling needs adjustment after the springs were installed?
Some more pics taken this morning before work:
Wow, where do you work, right on the coast?! I see water in the background of that last picture. Really beautiful, but there's a car in the way![]()
good thanks that front grill you have, who makes it? I just noticed that grill. I actually dislike the OEM mazda grill with a passion. It's a horrible looking grill. Love everything else but that grill...ugh
Were your measurements from the center of the wheel? Or from the ground. They would need to be from the wheel center b/c the new larger wheels will still affect measurement.
You can adjust the headlight. At least on the old his there is a plastic screw you turn.
"Good thanks" - Cracking looking motor mate ...love the Wheels.
