Hi,
I released on my previous posting, I posted in the wrong thread. I asked if anyone had squeaking suspension sound and seems like no others had one. I wend to the dealer and they tightened all suspension areas including sub frames. The squeaking has been reduced but not totally gone. They said that in Canada, unless squeaking are caused by manufacturing defects like shocks, it is not covered by warranty.
My question is when driving over brick / cobble stone roads, it squeaks and cannot tell if it is from front or rear of the car. It seems to come from both sides somewhere under the car.
What should I do now. Is there an area in the suspension area that I need to concentrate in lubricating? Sway bar bushings? Sub frame bushings or shock mounts? or all of above?
If some one who have read or heard which areas I need to lubricate to resolve this problem will be appreciated. What do I need to use, white lithium grease?
Any advise will be great.
Thank you
Thank you
