Mazda of the Month | ENTER NOW for June!
Status
Not open for further replies.
I got my wheels before boost I would have had boost if I didn't buy wheels
Sent from my SM-N900V using Tapatalk
Woot woot! Antoine could you change the theme to Wheels and Suspension? Technically a rim is only part of a wheel, and with everyone in this having such nice wheels, it would be nice to use the correct terminology :)
Done and done!
MM BOOST
Kevin Jenkins
2007 Mazdaspeed 3 GT
Exterior
-OEM Mazda upgrade fender flares (made for Mazda 3) color matched Cosmic Blue
-Wing lip extension
-LED Smoked Tail Lights
-Color matched Cosmic Blue headlights with TRS lenses and 6k HIDs (DDM Tuning)
-3k HID fog lights (DDM Tuning)
-black led side markers with black surrounds
-STi V-limited Front Lip
-JDM V2 side skirts
-Nextmod Gen2 Speed 3 rear lips
-DG Racing Rear Diffuser
-blacked out reflectors
-blacked out upper and lower front grills
-blacked out front and rear Mazda emblems
-carbon fiber rear Mazda emblem inserts
-debadged and side moldings removed
-sickspeed quick releases
-sickspeed rear tow strap
-VG Shark Fin Antenna
-Mugen-style Window Visors
-35% tint
-Lamin-X Ice Blue fog light covers
-CP-e Tow Hook License plate relocation
-LED rear license plate lights
-LED reverse lights
Suspension/Brakes/Wheels
-BC Coilovers - maxed front, maxed rear with no collars - maxed front camber with dremeled shock towers
-SPT rear camber arms - maxed
-Progress Rear Sway bar
-SURE Front Polyurethane sway bar bushings
-StopTech rotors with Hawk HPS pads
-18x9" +25 Wedssports SA60M with carbon fiber caps
-Yokohoma Envigor 225/40/18
-Muteki Burning Blue lugs
-Endless matched valve stem caps
-fenders pulled heavily
Performance/Under the hood
-Turbo XS Front Mount Intercooler
-DNP V3 Exhaust Manifold
-Turbo XS Downpipe
-Turbo XS Race pipe
-Greddy Ti-C catback exhaust
-JBR Stage 2 Intake with inlet
-Tial QR / CP-e Blow-off valve kit
-Autotech CDFP internals
-Cobb AP V3
-JBR EGR delete
-Mishimoto Oil Catch Can
-CP-e Rear Motor Mount
-Street Unit billet blue caps
-PartPlazda carbon fiber hood lifts
-Corksport LED underhood kit with custom quick-release switch for shows
-JBR aluminum battery and fuse box covers
-Custom powdercoated parts - Wet White and Candy Blue Metallic
Interior/Trunk
-Redline Goods OEM Matched Black/Red stiching Short-shift, E-brake, and Arm Rest Cover boots
-TWM Short Shifter
-TWM Shifter bushings
-Sickspeed Cobra shift boot retainer
-Sickspeed White Old School shift knob
-Autometer Boost Gauge with red led swap to match interior mounted in cup on steering column
-Gloss White Mazdaspeed emblem on dash trim
-Corksport LED Interior swap
-NRG Powdercoated white harness bar
-NRG 5-point harnesses
-Zenclosures Mazda 3 custom sub enclosure
-Polk Audio sub grill painted gloss white
-Pioneer 12" sub
-Sony Xplode AMP
-Custom built "Iron Wood" trunk floor with hand polished handle/lift lever and Paul Walker tribute in middle of floor
-Custom hand-painted hatch cover with the word "KOVERT" - following an industrial-type theme with Iron Crosses and skulls
-LED strip custom wired/soldered to work in place of factory hatch light hidden in trunk floor to light up trunk
Thanks for consideration! So many nice cars and stiff competition in here!
SLWSPD3
Jovany Cuesta
2011 Mazdaspeed 3
Engine-
SURE motorsports:
turbo inlet pipe
short ram intake w/ element sheild
shortshifting weight
shortshifting plate
shortshifting bushings
boost tubes(intercooler pipe)
Tanabe tower strut bar
Exhaust-
Custom stright 3in to gutted
Magnaflow muffler w/ tips
Exterior-
HID 8K head lights
EnlightAuto LED fog lights
STI front lip
HIC window Visors
20% front window tint
15% rear window tint
Suspension-
Airlift front struts w/ camber plates
Customs rear bags
Custom rear lower control arms
Corksport Reese toe arms
Spc rear camber arms
Street unit front drilled and slotted rotors
Wheels-
Fully polished CCW LM5T's
Gold apr bolts
front:18x10
rear: 18x10
205/40 all around
Interior-
SURE short shifting bushings
Airlift V2
4 gallon air tank powder coated fluorescent white
Viair 444cc compressor
Grip Royal sleek steering wheel
NRG hub
NRG Quick release
NRG seat harnesses
NRG harness bar powercoated fluorescent white
HKS turbo timer
5 pannel mirror
12" rockford fosgate p1
1200 watt amp
custom wood floor(hatch floor)
GarageStar
Kenjo Raif
1997 Mazda Miata
Engine-
Garage Star Plug cover
Garage Star oil cap
Garage Star cooling panel
Garage Star wiper cowl
Garage Star brake master brace
Garage Star engine dress up bolts
Garage Star pulleys
Mishimoto radiator with slim electric fans
Toda Flywheel
ACT 3 puck clutch
Setrab oil cooler
Marhua Header
RS*R ExMag GTII exhaust
Custom aluminum overflow tank
KAAZ LSD
4.8 gearing
Exterior-
OEM Hardtop
RS Active headlights
Garage Vary front lip
Garage Vary tail lights
Garage Star side stripes
Mazdaspeed wing
JDM side markers
JDM front turn signals
Jubiride over fenders
Eunos front badge
Eunos rear badge
Garage Star license plate bracket
Garage Star front stainless steel towhook
Suspension-
Tein Flex
Garage Star frame rails
Garage Star fender braces
Garage Star rear chassis brace with tow hook
Garage Star subframe collars
Garage Star diff bushings
Racing beat front sway bar
949 end links
extended inner tie rods (for better angle)
Supernow outer tie rod ends
Wheels & Brakes
4x100 14x8 -11 SSR Reverse Mesh
SSR 90 degree valve stems with SSR caps
195/60/14 Falken Azenis
Technafit brake lines
Carbotech pads
Brembo rotors
Interior-
Custom full roll cage
Garage Star hardtop latches
Garage Star security bolts
Garage Star seat rails
Garage Star gauge faces
Garage Star minimalist center console
Garage Star 4" shift extender
Garage Star shift knob
Mazdaspeed short shifter
Bride Zeta II
Nardi classic steering wheel
Daikei hub
Techno Toy Tuning 50mm hub extender
KG Works gauge panel
Shroth harness
I do very much like your car and I mean no disrespect but I thought the limit of photographs was a 5? Just asking since there's a few more than that in your entry! Very (cool)
MM BOOST
Kevin Jenkins
Exterior
-Wing lip extension
-JDM V2 side skirts
-35% tint
-LED reverse lights
-Turbo XS Downpipe
-Turbo XS Race pipe
-Cobb AP V3
-JBR EGR delete
Interior/Trunk
-TWM Short Shifter
-Pioneer 12" sub
-Sony Xplode AMP
I do very much like your car and I mean no disrespect but I thought the limit of photographs was a 5? Just asking so I know how many are allowed
Status
