Second fill up @ 4 miles to empty on the range meter gave me 392 miles on this tank. When I filled it up it once again it stopped filling at around 13 gallons, but I kept topping it off until it climbed all the way to 15.8 gal !!! I thought the tank size was 14.8 (for FWD). What gives???
You are brave running it down that low.
Fill slower once you reach the 10-12 gallon mark and you won't have this issue as dramatically.
According to some posts above, there should be ~50 miles (2 gallons) left when the range meter gets to 0. I wasn't concerned.
Thanks, I did follow your tip this time but it didn't seem to help. Kind of troubling that it says it's full but you can really put up to 3 additional gallons after that. Will bring it up to the dealer...
I have a few friends that are mechanics and another that works at a warranty company and there's a direct correlation between in-tank fuel pump failures and running the tank low. It's damn hot here in the summer.
And it's not fuel you're never going to use on a sky active engine, it's a reserve to prevent you going to the dealer and paying for re-bleeding the high pressure fuel system.
You can do what you like... it's only money.
I have friends that are mechanics as well and they all disagee and say with a modern car the 1/4 tank urban legend is ridiculous. Fuel flowing through the pump cools it. No vehicle engineer is going to design a part that will fail when used under normal conditions then tell their customers "welp, shoulda kept'er above 1/4 tank cause I designed that pump to be sub-par!".
Believe anything you want but spreading misinformation does a disservice to others.
Typical fuel injected cars have around 80psi $70 fuel pump. An 80psi pump won't be hurt running dry.
The direct injected CX-5 runs a 150psi $150 in-tank pump into a 1000psi $600 fuel pump. The 1000psi fuel pump would most likely be damaged if it ran dry. At $600, I'll make sure I never run low on gas in the CX-5.
You know how to prevent from running out of gas? Fill up at 1/4 tank...
You can't predict what's going to happen out on the road so give yourself some extra padding. It took me 6 hours to make a 2 hour trip once and I'm sure glad I wasn't already pushing the tank to empty.
Also, on board mileage is calculated by wheel rotation. It's really just a ball park way to monitor your driving habit and efficiency. Have you tried a GPS app to track your mileage? For some it can be off by a noticeable amount.
Isn't 25MPG the EPA mileage? Not sure what you're so upset about. It's what I've been averaging with warmer weather and no snow to deal with.
