Hi all,
I initially sat down to type this out as a sort of brain dump to check my work but I figured I might as well post it.
All the headunit installation threads lately inspired me to give it a shot. I'm not a completely inept DIYer but I'm trying to sort out a headunit installation in my 2014 GT and the wiring is confounding me. Unfortunately, there's not an installer within 80 miles of me and I am in need of some guidance. I think I'm close, but things aren't quite working perfectly. Sorry to ask for such hand-holding, but please accept my very humble thanks in advance.
Headunit: Parrot Asteroid Smart
Steering wheel control interface: Axxess ASWC-1 with 4-pin AX-SWC-PARROT adapter
Other parts: Metra 70-7903 harness, Axxess AX-MAZUSB USB adapter, Metra 40-HD10 antenna adapter
Symptoms I'm experiencing: The headunit powers up but the sound is extremely quiet. At max volume, I can only just hear a source playing. The ASWC-1, however, seems to neither power up nor (duh) allow any steering wheel controls.
A quick rundown of the connection diagrams, first the Asteroid Smart harness:
and the ASWC-1 instructions for this vehicle. I remember that RedBaron mentioned the missing pins in this harness. Also, I moved pin 1P, which was to be grounded in step (4), over to pin 1H, which was missing, and then connected that to the ASWC's grey/red wire as instructed in step (5). Can I get away with this?
Here's all of my current connections:
[M]azda harness
[AX]xess ASWC-1
[AS]teroid Smart
[M] yellow -- [AS] yellow (12V+)
[M] orange -- [AS] pink (illumination?)
[M] blue -- [AX] grey/red (steering wheel controls)
[M] red -- [AS] red -- [AX] red (ignition ACC)
[M] black -- [AS] black -- [AX] black (ground)
[M] blue/white -- [AS] dark blue -- [AX] white/green -- [ANTENNA] blue (power antenna / amp turn-on)
[AS] black (pin 2) -- [AS] light green (parking brake bypass)
[AS] orange (reverse 12V+, haven't bothered with camera yet)
and now, a large shot of the harness as currently assembled. I'm aware that electrical tape isn't at all ideal but I was doing it this way to test the connections before I solder them. As I learned from mentalcase's thread, I connected RCA cables from an extra amp interface harness to the speaker wires from the Mazda harness, with the shielding to speaker negative and inner wire to the positive.
and a close-up of the antenna/amp connection. The Asteroid came with an ISO harness, which I just cut off to use the wires, but there were still some of the quick-connections in between. I checked them and they seem snug but should I just cut them out?
and finally, the ground wires from each harness:
Thanks for looking. Tell me why I'm an idiot.
[M]azda harness
[AX]xess ASWC-1
[AS]teroid Smart
