Thanks, and thanks for the help on posting the pics. Are you still in NJ?
Copy catglad you started a build. We need to set a date for the group bushing install
I'm all for helping you and Rich nstall them, not sure it they are "needed" though. I guess every little bit helps.
I'm probably only going to install caster, but if I have the arm out might as well install the other front arm busing.
Never got them to Chris, went with the Bilsteins and have had some good results so far. Seems if anything, car needs more rear shock, and not so much in the front. More rebound in the rear seems to just make a mess so something with more(and adjustable) bump is what it's going to take to get the car more balanced.I thought you were running those custom dampers from red shift, did it not work out?
In the rain, the car is awesome right now, but in the dry, there's just not enough rear rotation on higher grip surfaces.
