Hi Konstaninos, sorry what happened to your engine
At the moment that your engine is in these conditions, I would like to ask a favor
to take different measures in order to investigate connectig rods and pistons which we can use
- Volume of combustion chamber CC
- Piston height, taking the measurement from the center of the piston pin to the top
- Head Gasket thickness
- Deck height, taking the measurement from the center of the crank to the top of the block
I would appreciate if you can get this information
It was exactly for this is that I wanted the measures.
my idea is use forged con rods for FS. are the same that use the mazda3 1.6 (z6 engine) but i cant find what pistons can we use whitout lose so much compression
The rod broke due to the torgue. If there was a problem with the CR the first thing to have a problem should be the piston.
No, the gasket was fine.
those are some pretty pistons! do the the heads have "up" printed on them?...that would be a hell of a mistake to goof that up.
There is a long way ahead for 30psi...30 psi?
-Derrick
