doubleKlutch
- 2002 Mazda Protege5
My 2002 P5 is sick.
- Loses about 1/2 Quart of oil every day, or every 40 miles. (lots of oil going somewhere)
- Power wanes above 3500 rpm, you can feel very small waves of power/lack-of-power as it climbs through 4-5-6k rpm.
- Fuel Economy is fine, about 28-30 mpg
- Whisper of black smoke in the rearview above 4k rpm, but it's lost in the wind (Rich fuel?)
- No oil in coolant or coolant in oil (head gasket is good?)
- Minimal oil leak at rear main seal, no stains on driveway (not leaking)
- Minimal blowby, measured at the oil cap (rings are good?)
- Light unidentified occasional rattle, not heat shields (broken, clogged cat?)
- Occasional small blue smoke puff on startup, can only be seen from outside, behind the car
- Rare massive billow of blue cloud 1 out of 10 startups
- no smoke at idle, and none seen from rearview under normal driving conditions
The car seems to need valve seals, but I'm not sure what else. That's a lot of missing oil to not see coming out. Anybody seen this mix of symptoms on another Mazda? Could they all be related?
