Installshield 2
Gothenburg Superiority
I had a KL v6 probe GT before my P5...A bad pcv valve did nearly exactly what you're talking about...the valve would stick completely open, and it would just squirt oil straight into the intake system...$5 fixed it, but it made a complete mess of the intake system...no leaks, no noticeable driving problems...weirdly...but white smoke everywhere under throttle...
you're VC mod sort of addresses this, by blocking the pcv valve some what...but if you're positive your compression is good...the only way to burn that kind of oil with good compression is either improper re-circulation (pcv valve), or the turbo bearing (which you said is new, so not this)...so i'd suggest looking into replacing that valve, its practically free...
lastly...if it comes back...try and get a video of whats coming out of the exhaust...'white' vs. 'blue' vs. 'black' smoke is somewhat subjective in some cases...burning oil, and the smoke because of it...isn't always a vanilla 'white'...and burning coolant very much can cause white'ish exhaust, too...it depends on relative humidity and a whole bunch of annoying other s***...a video with a description of things like relative humidity, was it a completey cold start, ambient temps, etc...should help give you better feedback quickly...
but from what i can tell...something is, or was, pumping pure oil directly into the chambers...which could a be a lot of things...valve seals installed incorrectly, for example...considering your valve cover mod seems to have helped, i'm guessing it had something to do with the pcv system...
