Mazdaspeed2oo35
600whp - 600wtq at 30 PSI
Miguel how do we get those cups?? Also Maxx you should try PAR double synchro with custom gear ratios.
Pretty soon i will start a GI thread to see how many people wants to get rid of breaking gears. what PAR did is not funtional since all they did was putting the bearings on separate Sleeves. that does nothing it will expand and flex under heavy loads and high oil temps. my special brace have been storied and engineered by a wrc mechanic friend of mine and will trully prevent oem, and aftermarket gear sets
from not being engaged all the time preventing the 2 towers of gears to separate creating what we all know it happends teeth damage. teeth breaks because they are not fully engaged. if they separate just a bit kaboon.. Helical cut gears are whole lot stronger than Straight cut but the handicap is they tend to separate from each other do to the angle they are made. if you keep all teeth in and fully engaged they are stronger than straight cut but you need to help the transmission case to not flex under heavy loads. sorry my english is kind of limited to explain all my friend have. hes a retired world rallye car mechanic. now he owns his own shop and all he does is racing and rally car builds.
