Has anyone seen these projector headlights?
Looks just like the folks on here that have done the conversion, but without all the baking in the oven and work etc. Aside from projector, housing looks stock. Side reflector is the non u.s. version since it has a clear reflector
I got these! Ordered them from alibaba and not alibaba express but they worked. Well sorta, weren't that bright and I found better ones I wanted to get so I returned them.
The US version has that orange reflector for DOT requirment reasons right? I wonder how much (if any) attention you would really get from any law enforcement if you installed J Spec headlight housing...
I hate to say it, but for $700+ after shipping... There are better and cheaper conversion kits available that people on here have used... A bit more elbow grease i suppose but still.
Those projectors used are junk, trust me
As to retrofits, the parts to do a retrofit using parts from TheRetrofitSource can be had for $270 shipped to your door (if you trust yourself to take your lights apart)
These are the same lights but those on the left i painted and retrofitted (Yeah, i know they're protege lights but it's just for ref)
10-15 min in the oven at 200 and they come apart like butter
It will fit just watch for the upper heating element.. Also wrap it with some cloth to protect it just in case
Thanks for the heads up. I was able to fit the headlight in the oven just right with about a half a centimeter to spare on each corner. Placed it on one of the oven trays slotted almost at the bottom. Covered the tray with foil. 200 degrees for 15 - 20 minutes and everything went great. No issues what so ever. ;)
