thecrash91
- 2003.5 Mazdaspeed Protege
ok so heres the story. I have a coupler that keeps popping off and its driving me nuts. The pipes its connecting are the only ones that arent beaded because i had to cut my IC pipe. After installing GT28rs the perrin tubing was about an inch too short so i bought a coupler thats 3 inches in length, cut the tube and just extended it 1 inch with the coupler. So that leaves only an inch of pipe on each side to grip plus the fact its not beaded. Ive tried clamping it down as much as possible i even bent the tube a bit (i bent it back though) and it keeps popping off. the side that popped off last was the side that wasnt bent so that didnt do it. Ive also tried hair spray but to no avail. my next step is to use gorilla glue, either give me one good reason why i should, or why i shouldnt (then give me something else i could use) the only reason not i could think of would be if the glue ate away at the silicone coupler. HELP!!
