opened a parcel this morning.. looks like i can finish the plumbing tonight on the car, Thanks CR3
laser blue is Midnight Blue's b****...just sayin'
My dirty car has a better finish than your clean car lol!
Ya i disagree.. here's my dirty car after being in the garage covered in dust for 5 months.. cell phone pic as well and notice the reflection..
and as for what i did to the car today.. nothing yet but i have a whole box of parts waiting for me to get home from work to install..
You have aftermarket color with more pearl. You're disqualified JT, that's no longer OEM Laser Blue lol
thats already in the works ;), but i still like the OEM tails as well
I like the OEM. I like how the JDM's light up on the bottom and the lines flow with the body, yet I got the tint and clear just right on my tails and can't part with them.
Here are some of my fave shots
Still has a hint of laser blue.. its just tweaked enough to be different.
and if my after market paint/clear does not count.. your aftermarket clear does not count.. ;)
Azuelke: which brand of paint is that? i want to do my mp3s in that color.
Started off with 2 coats of black plasti-dip, followed by 2 coats of Valspar gold, followed by 2 coats of Valspar gloss clear. I'll take a pic of the cans after work. The gold was extremely metallic and had a lot of flake in it, until I put clear on them and it killed that pop, which is what I was hoping for.
BEFORE CLEAR:
AFTER CLEAR:
There was also a satin and matte finish gloss, I thought of doing matte, but I wanted to get as close to the sticker on my back as possible.
The Cooling System at 100%.
Checking For Leaks
Making sure that the system will not create cavitation in the coolant.
<iframe src="http://www.youtube.com/embed/QcnhyJP1RDg" allowfullscreen="" frameborder="0" height="315" width="560"></iframe>
Cranked Engine over with Oil on pistons, No Spark Plugs until I saw Oil Pressure (10 Seconds)
So A List of what is left.
Wire Oil Temp Sensor (2 Wires)
Wire Home (1 Wire)
Wire Trigger (1 Wire)
Power to RA-10 (2 Wires)
Verify Trigger and Home are read by ECU
Wire Injector Power (1 Wire and insert Fuse)
Ignition System (Insert Fuse)
Gap 4 Plugs
Connect Fuse for Fans
Connect Fuse for Water Pump
Check Levels
Run Up Car to operating temperature and shut off. (No Driving)
