Are you certain its a downshift to 5th? Mine will skip 5th and go directly to 4th if I am asking for a fair amount of power. A slight power command gives me 5th and is far less noticeable.
Also, the rate at which the pedal is pressed appears to influence the transmission control module. If I quickly press a slight distance, I can get the transmission to downshift. If I slowly press the same distance to holds on to the current gear. Anyway, my point is that I think the inputs and algorithms used by the TCM are fairly complex....so something unnoticeable to you could be different between the smooth and harsh case and you just aren't observing it?
Experienced the same thing. If I am above 110kmh and want to say overtake someone, there is a harsh shift into 5th. Not sure if it is solely the transmission or a combination of the TCS and AWD torque kicking in.Do other CX-5 auto tranny owners occasionally get a harsh downshift into 5th at speeds of 65+? I noticed it a few times at freeway speeds, otherwise it works fine.
I agree, this has never happened with casual driving, only when I boot it. Plus, I tend to have a bit of a lead foot on the highway. (whistle)dasayheykid - Yes, that's what I've experienced. It's probably something that only aggressive drivers on high speed freeways would ever experience. It's probably not a problem, because the shift is fast and firm.
Yeah I'll do the same. Good to know i wasn't the only one who has experienced it, but like you said its not that bad.I suspect our driving styles are similar, lol.
I'll keep tabs on this downshift behavior, not that it's really that bad.
If I set cruise at say 65mph and i start going downhill, the transmission will downshift into 5th to keep the speed at 65 without having to apply brakes.
Never felt particularly harsh to me yet. I will keep a close eye on it and see if anything changes.
What you're looking for is a slight jerk when you are at around 65mph, and then floor it. The jerk happens when the car downshifts from 6th to 5th, or possibly kicking in the AWD at such a speed.
Congrats on your purchase btw.
The 5th gear downshift is smooth for me most of the time. However 6th to 4th or 5th to 4th is most often loud and clunky. And sometimes the trans decides it wants 3rd then has a violent clunk revs to 5k+ and then I have to let off cause the trans won't engage. This was during steep mountain driving situations and during freeway passing around 60 mph. It's not right. Going to the dealer this week. I'm not sure what they will do. Pry give me as designed bs. But mazda needs to know that something isn't right.
