Thanks for all that info, Berty...Much appreciated!
- You MUST have two fans - one that triggers when the AC is active and another that comes on at a certain temp.
Not sure if I will run fans initially, but if I do...I'll be sure to run two!
- Shrouds are a must. I have a massive aftermarket radiator and the un-shrouded electric fan did nothing.
I've realized this...No matter the fan type, size or use case...An effective shroud is critical in all cases.
- Get a proper temp gauge. After the mid-line, the next two lines on the factory temp gauge represent a 20 degree increase in temp!!!
I'm currently running an OLED Defi gauge with sensors reporting both Oil and Water Temp.
- The clutch fan is awesome. As others have said, the choice to go to electric fan should not be made based on power-adding.
What do you think about running the clutch fan AND two electric fans
- The twin turbo's generate most of your heat. If you are going to rebuild them, ceramic coat the housings and dump pipe. The under-bonnet temp difference is huge as a result.
Great advice...I hadn't thought about that but it makes a lot of sense...I often leave the hood open after driving to release the heat...I would like to find a way to vent the heat out...Possibly with super subtle hood vents or some other stealthy way.
I saw this custom vent at the 20th Anniversary Meetup...I really like how it looks...
As for the Stock Turbos...I'd like to get them upgraded someday (like what
http://bnrsupercars.com offers) and that would be a good time to get housing and exhaust ceramic coated!
- There is a coolant nipple on the rear iron. If this is leaking it will introduce air-bubbles into the system and cause over-heats.
Noted...Thanks!
- The factory oil cooler is huge and awesome. Only change this as a last resort.
I would like to see lower oil temps when in traffic and taking on intense mountain roads...I'm seriously thinking of adding an additional cooler in-line with the stock one...Maybe one with its own fan and shroud.
- The auto cooler is not as great. Change this for a unit with a thermo fan built onto it.
Noted...Planning on it!
- The Carbing cooling plate is over-priced but it does work. If you can find one cheap, grab it.
I've thought about getting one for a long time...If they are still in stock, I'm going to get one! Carbing products are beautifully made, love my front strut bar!
Here is my advice;
- Copper or Aluminum radiator - at least twin past. Don't worry about the auto's heat exchanger.
In Japan, they use the term "cores" (2 core is standard...3 core is beefy)...What exactly does "twin pass" mean
- Clutch Fan with the thermo fan replaced with a higher rated SPAL unit. 12 to 14 inch.
As previously mentioned...What are your thoughts on running the stock clutch fan AND two radiator fans
- Ceramic coating of the turbo housings and dump pipe
Noted!
- Ensure all under-trays are in good nic.
Noted!
In the plans...Maybe not in Stage 1 of cooling upgrades but definitely in the pipeline!
- Leave the factory oil cooler alone
Will do...Most likely adding a second cooler as backup!
- B&M Auto cooler with built in thermo fan.
Being in Japan, I'm going to have to see what the best options are for my budget.
- Ensure that there are no pressure leaks in the system - especially from the rear iron area which is susceptible.
Noted...Will do!
Here is what I am running now...
- Twin electric fans from a BA Turbo falcon. Fan one turns on with air-con, fan two comes on at 85 degrees. Temps never exceed 90 degrees.
- Twin pass allow radiator (58mm thick)
- RX7 Reverse V-Mount cooler
- Stock oil cooler
"Temps never exceed 90 degrees." That's my goal and it would be a major relief not to worry about temps, especially in summer!
